I have an old-ish System76 galago pro (galp3). Until today my webcam was working fine.
I just upgraded it to 22.04 (from 20.04). The machine boots fine and the login screen with 3 users shows up. Within a second or two, the webcam active light comes on and stays on.
Cheese doesn't work, it says "There was an error playing video from the webcam".
Some debugging info:
$ journalctl -b | grep -i bison
Aug 11 16:55:12 compy386 kernel: usb 1-7: Product: BisonCam, NB Pro
Aug 11 16:55:13 compy386 kernel: usb 1-7: Found UVC 1.00 device BisonCam, NB Pro (5986:2112)
Aug 11 16:55:13 compy386 kernel: input: BisonCam, NB Pro: BisonCam, NB  as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/input/input22
$ lsusb | grep Bison Bus 001 Device 002: ID 5986:2112 Acer, Inc BisonCam, NB Pro
$ cheese Aug 11 17:03:40 compy386 cheese[5341]: Device '/dev/video0' is busy: ../sys/v4l2/gstv4l2object.c(4033): gst_v4l2_object_set_format_full (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin18/GstV4l2Src:v4l2src1: Call to S_FMT failed for MJPG @ 1280x720: Device or resource busy
$ uname -a Linux foghorn 5.18.10-76051810-generic #202207071639~1657252310~20.04~7d5e891~dev-Ubuntu SMP PREEMPT_DY x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 22.04.1 LTS Release: 22.04 Codename: jammy
Any ideas?
Adam Monsen
  • 2,161
Ah, it was motion! I contacted System76 support and they suggested using fuser like so:
$ sudo fuser -v /dev/video*
                     USER        PID ACCESS COMMAND
/dev/video0:         motion     7943 F...m motion
I forgot I was tinkering with motion a while back. Maybe something during the upgrade changed motion to start automatically.
Thank you Matt at System76! Fixed with
sudo systemctl stop motion
sudo apt autoremove --purge motion
Now the webcam active light is usually off except when I use something like cheese.
Note that lsmod | egrep '^Module|uvcvideo' was also helpful (thanks again, Matt!) to see that 1 thing is using the USB webcam while motion or cheese is running, and 0 things when they are not.
Adam Monsen
  • 2,161
