I've been learning docker which has led me to create a container with ubuntu. I am also kinda new to linux commands in general and was trying to get a better understanding of redirection.
I used > to send outputs of commands to files like so
ls -l > dir_contents.txt
I also used | to process ls -l so I can get just the file name like so
head -n 1 ~/etc_content.txt | awk '{print $NF}'
Now what I want to do is send the previous command to cat so I can list the contents of the file. What I am currently doing is
cat < head -n 1 ~/etc_content.txt | awk '{print $NF}'
This tells me there is no file or directory after running that command. I think that means it worked but my path is messed up somehow?
The data I am directly working with is the filename adduser.conf in the directory /etc. So I am not certain what the problem may be.
Edit: Grammar fix
