I'm trying to build my first vm image using Packer.io, vmware fusion and Ubuntu 22.04 autoinstall. Following this example https://www.youtube.com/watch?v=HHaG_ra5QFw
Packer creates the vmx, start the vm and passes the boot commands to grub successfully. The ubuntu installer runs and eventually gets to the Welcome screen waiting for language selection. Packer fails to ssh into the vm SSH handshake err: ssh: handshake failed: ssh: unable to authenticate... then eventually times out, kills and deletes the vm, so I have little to investigate.
watch the logs of the vm console, and Packer... It looks to me like the user-data is never retrieved. I have verified that packer successfully started the http server, and user-data is available. For unknown reason, it doesn't appear the ubuntu installer is trying or at least successful retrieving user-data... which would explain the ssh failure as the user was never created...
Although the logs scream by on the vnc console, I've paused and looked through them and see no indication that ubuntu is retrieving user-data...
check your web Server log, you can see clearly the download of the iso image and if so the download of the user-data file. There seems to be similar issues user-data file not picked up by Cloudconfig in
Install with PXE of ubuntu 22.04 blocked and pxe autoinstall fails with ubuntu 20.04.04 you may test to adopt the cloud-config-url pointing directly to your user-data pls share the log of your web server if if fails.
dummyuser
  • 1,088
