I am trying to reduce the filesize of a pdf using ghostscript. I found the command here: https://tex.stackexchange.com/questions/18987/how-to-make-the-pdfs-produced-by-pdflatex-smaller
gs -sDEVICE=pdfwrite -dCompatibilityLevel=1.5 -dNOPAUSE -dQUIET -dBATCH -dPrinted=false -sOutputFile=foo-compressed.pdf input_file_name.pdf
   **** Error 'gs' ignored -- ExtGState missing from Resources.
        Output may be incorrect.
I also executed the command without -dQUIIET and -dNOPAUSE, but that didn't clarify the problem:
GPL Ghostscript 9.55.0 (2021-09-27)
Copyright (C) 2021 Artifex Software, Inc.  All rights reserved.
This software is supplied under the GNU AGPLv3 and comes with NO WARRANTY:
see the file COPYING for details.
Processing pages 1 through 72.
Page 1
>>showpage, press <return> to continue<<
I don't know what ExtGState means hence that I don't know what further steps are needed to solve the problem.
EDIT1
The command does put a PDF file out that is smaller. So it seems to work. I am simply unsure what the error means and whether it needs to be fixed and how.
adding -dPDFSETTINGS=/prepress does not remove the error.
Pdffonts
pdffonts original.pdf
name                                 type              encoding         emb sub uni object ID
RLEATT+Aniron-Bold                   CID TrueType      Identity-H       yes yes yes     11  0
JETQLW+CrimsonPro-Regular            CID TrueType      Identity-H       yes yes yes     13  0
CZPFND+CormorantSC-Bold-Identity-H   CID Type 0C       Identity-H       yes yes yes     19  0
APXFPL+CrimsonPro-Italic             CID TrueType      Identity-H       yes yes yes     74  0
VTLLQQ+CrimsonPro-Bold               CID TrueType      Identity-H       yes yes yes    148  0
BCDEEE+Calibri                       TrueType          WinAnsi          yes yes no     770  0
BCDFEE+MS-PGothic                    TrueType          WinAnsi          yes yes no     774  0
BCDGEE+Wingdings-Regular             CID TrueType      Identity-H       yes yes yes    778  0
BCDHEE+Calibri-Bold                  TrueType          WinAnsi          yes yes no    2816  0
CXSUEN+LMMono10-Regular-Identity-H   CID Type 0C       Identity-H       yes yes yes   2888  0
BCDEEE+MinionPro-Regular             TrueType          WinAnsi          yes yes no    2899  0
BCDFEE+Aniron-Bold                   TrueType          WinAnsi          yes yes no    2904  0
BCDGEE+TimesNewRomanPS-BoldMT        TrueType          WinAnsi          yes yes no    2909  0
BCDHEE+MinionPro-Bold                TrueType          WinAnsi          yes yes no    2915  0
BCDIEE+MinionPro-Regular             CID TrueType      Identity-H       yes yes yes   2922  0
BCDJEE+TimesNewRomanPSMT             TrueType          WinAnsi          yes yes no    2929  0
BCDKEE+SymbolMT                      CID TrueType      Identity-H       yes yes yes   2937  0
BCDLEE+ArialMT                       TrueType          WinAnsi          yes yes no    2946  0
BCDMEE+Aniron                        TrueType          WinAnsi          yes yes no    2955  0
BCDNEE+MinionPro-Bold                CID TrueType      Identity-H       yes yes yes   2968  0
BCDOEE+MinionPro-BoldIt              TrueType          WinAnsi          yes yes no    2978  0
BCDPEE+MinionPro-It                  TrueType          WinAnsi          yes yes no    2983  0
BCEAEE+TimesNewRomanPS-ItalicMT      TrueType          WinAnsi          yes yes no    3051  0
AJWSEY+CrimsonPro-BoldItalic         CID TrueType      Identity-H       yes yes yes   3195  0
Natan
  • 1,059
The source PDF file is malformed. Ghostscript ignores the malformed part but cannot promise that the result looks as it was originally intended. The 'gs' in the message refers to a PDF operator, rather than the Ghostscript executable.
To fix this error you need to modify the source PDF file or the program that generated it.
