I recently bought a MacBook Unibody from 2010, and would like to install Ubuntu on it (this would be my first time installing or using Ubuntu). Before installing Ubuntu, I plan on removing the hard drive and installing a new SSD. After some research, I believe the plan below would work, but thought it would be best to check as this is my first time installing an SSD and my first time using Ubuntu.
- Follow the first 3 steps here to create a bootable USB stick.
- Physically remove the hard drive and install the blank SSD.
- Power the MacBook on while holding the Option (or alt) key to access the boot menu (I'd be a bit concerned about this not working).
- Follow the rest of the steps in the tutorial to install Ubuntu.
It's a new laptop, so I don't need to worry about losing anything. Does this look like the correct approach for my situation? Is there anything else I need to be aware of / careful about?
Thanks a lot in advance!
