Why do I get an automatic crash as soon as I boot up into Unity?
$ sudo startunity
Entering /mnt/stateful_partition/crouton/chroots/focal...
dbus[10824]: Unknown username "whoopsie" in message bus configuration file
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
X.Org X Server 1.20.13 X Protocol Version 11, Revision 0 Build Operating System: linux Ubuntu Current Operating System: Linux localhost 4.14.277-19080-gea2f6526b6dc #1 SMP PREEMPT Sun Jul 17 19:39:27 PDT 2022 x86_64 Kernel command line: cros_secure console= loglevel=7 init=/sbin/init cros_secure drm.trace=0x106 root=/dev/dm-0 rootwait ro dm_verity.error_behavior=3 dm_verity.max_bios=-1 dm_verity.dev_wait=1 dm="1 vroot none ro 1,0 5767168 verity payload=PARTUUID=43e53ec1-0972-784e-a584-2d27bf3b1e1f/PARTNROFF=1 hashtree=PARTUUID=43e53ec1-0972-784e-a584-2d27bf3b1e1f/PARTNROFF=1 hashstart=5767168 alg=sha256 root_hexdigest=5c801cd079f824f962ae960d96ee373b10001fa32c7d5d59470f20226da0b8e3 salt=d21543438d95f9cf691f414db8c5c56964d0e305db7ecb44c51831c8af794967" noinitrd vt.global_cursor_default=0 kern_guid=43e53ec1-0972-784e-a584-2d27bf3b1e1f add_efi_memmap boot=local noresume noswap i915.modeset=1 gsmi.s0ix_logging_enable=1 intel_idle.slp_s0_check=1
Build Date: 06 July 2022 01:53:24PM xorg-server 2:1.20.13-1ubuntu1~20.04.3 (For technical support please see http://www.ubuntu.com/support) Current version of pixman: 0.38.4 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (++) Log file: "/tmp/Xorg.crouton.1.log", Time: Sat Aug 6 21:53:01 2022 (==) Using system config directory "/usr/share/X11/xorg.conf.d" Error org.freedesktop.DBus.Error.ServiceUnknown: The name org.chromium.LibCrosService was not provided by any .service files method return time=1659840782.082497 sender=:1.43 -> destination=:1.487 serial=14516 reply_serial=2 boolean true error: Kernel is too old for Iris. Consider upgrading to kernel v4.16.
(II) modeset(0): Initializing kms color map for depth 24, 8 bpc. crouton: version 1-20220111101058~master:a9eafaee release: focal architecture: amd64 xmethod: xorg targets: unity host: version 14816.131.0 (Official Build) stable-channel octopus kernel: Linux localhost 4.14.254-19080-gea2f6526b6dc #1 SMP PREEMPT Sun Jul 17 19:39:27 PDT 2022 x86_64 x86_64 x86_64 GNU/Linux freon: yes Running exit commands... /usr/bin/xinit: connection to X server lost
waiting for X server to shut down Hangup Error org.freedesktop.DBus.Error.ServiceUnknown: The name org.chromium.LibCrosService was not provided by any .service files method return time=1659840788.847275 sender=:1.43 -> destination=:1.489 serial=14524 reply_serial=2 boolean true (II) Server terminated successfully (0). Closing log file.
Unmounting /mnt/stateful_partition/crouton/chroots/focal...
If it is my kernel, how do I upgrade to 4.16 without being able to access the terminal in Ubuntu?
Nmath
  • 12,664
paco
