I'm on Ubuntu 21.04 and trying to install packages. I had no problems until today, now I have those errors showing up:
$ sudo apt update && sudo apt upgrade -y
Ign:1 http://gb.archive.ubuntu.com/ubuntu hirsute InRelease
Ign:2 http://gb.archive.ubuntu.com/ubuntu hirsute-updates InRelease
Ign:3 http://gb.archive.ubuntu.com/ubuntu hirsute-backports InRelease
Ign:4 http://gb.archive.ubuntu.com/ubuntu hirsute-security InRelease
Err:5 http://gb.archive.ubuntu.com/ubuntu hirsute Release
404 Not Found [IP: 185.125.190.36 80]
Err:6 http://gb.archive.ubuntu.com/ubuntu hirsute-updates Release
Err:7 http://gb.archive.ubuntu.com/ubuntu hirsute-backports Release
Err:8 http://gb.archive.ubuntu.com/ubuntu hirsute-security Release
Reading package lists... Done
E: The repository 'http://gb.archive.ubuntu.com/ubuntu hirsute Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://gb.archive.ubuntu.com/ubuntu hirsute-updates Release' no longer has a Release file.
E: The repository 'http://gb.archive.ubuntu.com/ubuntu hirsute-backports Release' no longer has a Release file.
E: The repository 'http://gb.archive.ubuntu.com/ubuntu hirsute-security Release' no longer has a Release file.
And for the package I'm trying to install:
$ sudo apt install gcc-10-plugin-dev
Building dependency tree... Done
The following additional packages will be installed:
libgmp-dev libgmpxx4ldbl libmpc-dev libmpfr-dev
Suggested packages:
gmp-doc libgmp10-doc libmpfr-doc
The following NEW packages will be installed:
gcc-10-plugin-dev libgmp-dev libgmpxx4ldbl libmpc-dev libmpfr-dev
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,927 kB of archives.
After this operation, 12.4 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Err:1 http://gb.archive.ubuntu.com/ubuntu hirsute/main amd64 libgmpxx4ldbl amd64 2:6.2.1+dfsg-1ubuntu2
Err:2 http://gb.archive.ubuntu.com/ubuntu hirsute/main amd64 libgmp-dev amd64 2:6.2.1+dfsg-1ubuntu2
Err:3 http://gb.archive.ubuntu.com/ubuntu hirsute/main amd64 libmpfr-dev amd64 4.1.0-3build1
Err:4 http://gb.archive.ubuntu.com/ubuntu hirsute/main amd64 libmpc-dev amd64 1.2.0-1build1
Err:5 http://gb.archive.ubuntu.com/ubuntu hirsute/universe amd64 gcc-10-plugin-dev amd64 10.3.0-1ubuntu1
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/pool/main/g/gmp/libgmpxx4ldbl_6.2.1%2bdfsg-1ubuntu2_amd64.deb 404 Not Found [IP: 185.125.190.36 80]
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/pool/main/g/gmp/libgmp-dev_6.2.1%2bdfsg-1ubuntu2_amd64.deb 404 Not Found [IP: 185.125.190.36 80]
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/pool/main/m/mpfr4/libmpfr-dev_4.1.0-3build1_amd64.deb 404 Not Found [IP: 185.125.190.36 80]
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/pool/main/m/mpclib3/libmpc-dev_1.2.0-1build1_amd64.deb 404 Not Found [IP: 185.125.190.36 80]
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/pool/universe/g/gcc-10/gcc-10-plugin-dev_10.3.0-1ubuntu1_amd64.deb 404 Not Found [IP: 185.125.190.36 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
If I go to http://gb.archive.ubuntu.com/ubuntu/pool/main/g/gmp, for example for the libgmp-dev dependency, I can see that there is a file named libgmp10_6.2.1+dfsg-3ubuntu1_amd64.deb, but apt seems to be looking for libgmp10_6.2.1+dfsg-1ubuntu2_amd64.deb.
How do I resolve this problem?
