I've recently upgraded to 5.15.0.43, and I'm having trouble with a spotty Wi-fi connection using a Realtek RTL8723DE 802.11b/g/n PCIe Adapter.
When I'm connected with Wi-fi, the following occurs when I ping google.com:
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=631 ttl=117 time=494 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=632 ttl=117 time=1022 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=633 ttl=117 time=846 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=635 ttl=117 time=383 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=636 ttl=117 time=1017 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=637 ttl=117 time=16.5 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=638 ttl=117 time=179 ms
However, when testing with a wired connection (02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)):
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=686 ttl=117 time=10.1 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=687 ttl=117 time=9.93 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=688 ttl=117 time=9.62 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=689 ttl=117 time=9.91 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=690 ttl=117 time=9.77 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=691 ttl=117 time=9.91 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=692 ttl=117 time=10.2 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=693 ttl=117 time=10.3 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=694 ttl=117 time=10.00 ms
I've had this issue before when upgrading the kernel version (and I can't revert back to a version that works on boot as I'm three minor versions on from that)
Are there any suggestions as to what I can do to improve the wi-fi with this adapter? It is causing issues when syncing large files via Dropbox, which I don't get when wired.
The drivers I have been using, here: https://github.com/lwfinger/rtw88 have not been updated since 2020.
The result of lpsci -knn | grep Net -A3 is:
03:00.0 Network controller [0280]: Realtek
Semiconductor Co., Ltd. RTL8723DE 802.11b/g/n PCIe Adapter [10ec:d723]
    DeviceName: WLAN
    Subsystem: Hewlett-Packard Company RTL8723DE 802.11b/g/n PCIe Adapter [103c:8319]
    Kernel driver in use: rtw_8723de
    Kernel modules: rtw88_8723de
NB: I'm currently not at my home network, which is why I can try a wired connection to show such a difference.
EDIT: It's improved a bit, but I'm still dropping packets which doesn't happen with wired:
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=176 ttl=117 time=12.2 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=177 ttl=117 time=11.7 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=179 ttl=117 time=1027 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=180 ttl=117 time=13.3 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=183 ttl=117 time=1136 ms
64 bytes from lhr48s27-in-f14.1e100.net (142.250.178.14): icmp_seq=184 ttl=117 time=112 ms
user36196
  • 544
