Since this morning I have been able to resolve unmet dependencies.
In the past always solved it by installing packages one by one, or installing the deb package, but in this case I can't do that.
I need to install libvips-dev in Xubuntu 20.04:
sudo  apt install libvips-dev
The following packages have unmet dependencies: libvips-dev : Depends: libmagickcore-dev Depends: libmagickwand-dev Depends: librsvg2-dev (>= 2.40.0) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Also
sudo  aptitude install libvips-dev
The following packages have unmet dependencies: librsvg2-dev : Depends: librsvg2-2 (= 2.48.2-1) but 2.48.9-1ubuntu0.20.04.1 is installed Depends: librsvg2-common (= 2.48.2-1) but 2.48.9-1ubuntu0.20.04.1 is installed
The file /etc/apt/sources.list is the original,
In previous searches I saw many solutions and tried:
sudo apt --fix-broken install
sudo apt update --fix-missing
sudo apt dist-upgrade
sudo apt upgrade
sudo apt autoclean
sudo apt -f install
sudo dpkg --configure -a
Reading package lists... Done Building dependency tree
Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
sudo apt autoremove
sudo apt list --upgradable
Listing... Done
dpkg --get-selections | grep hold
give me nothing
I can not install the library then try with apt or aptitude to install some of their dependencies:
sudo apt install librsvg2-2=2.48.2-1 give me a big list of packages that will be removed
Then with aptitude, the same thing happens:
sudo aptitude install librsvg2-2=2.48.2-1
I must remove a lot of packages.
 Remove the following packages: 1 to 157
 Install the following packages: 157 - 164
 Leave the following dependencies unresolved:  161 to 187
If I do it, the system won't work anymore.
Also try: Synaptic->Edit->Fix Broken Packages
What I am doing wrong?
Is there any other package installer that can scan the repositories and recursively install all needed packages?
I suppose that apt and aptitude must to do it on its own.
The output of apt update is:
:sudo apt update
Get:1 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:2 https://download.docker.com/linux/ubuntu focal InRelease [57.7 kB]
Hit:3 http://ci.archive.ubuntu.com/ubuntu focal InRelease
Get:4 http://security.ubuntu.com/ubuntu focal-security/main i386 Packages [473 kB]
Get:5 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages [1637 kB]
Get:6 http://security.ubuntu.com/ubuntu focal-security/main Translation-en [278 kB]
Get:7 http://security.ubuntu.com/ubuntu focal-security/main amd64 DEP-11 Metadata [40.7 kB]
Get:8 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [1098 kB]
Get:9 http://security.ubuntu.com/ubuntu focal-security/restricted Translation-en [156 kB]
Get:10 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages [712 kB]
Get:11 http://security.ubuntu.com/ubuntu focal-security/universe i386 Packages [557 kB]
Get:12 http://security.ubuntu.com/ubuntu focal-security/universe Translation-en [129 kB]
Get:13 http://security.ubuntu.com/ubuntu focal-security/universe amd64 DEP-11 Metadata [66.6 kB]
Get:14 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 DEP-11 Metadata [2464 B]
Fetched 5321 kB in 19s (287 kB/s)
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
userone@pc:~
:apt list --upgradable
Listing... Done
linux-generic-hwe-20.04/focal-security 5.15.0.43.46~20.04.14 amd64 [upgradable from: 5.15.0.41.44~20.04.13]
linux-headers-generic-hwe-20.04/focal-security 5.15.0.43.46~20.04.14 amd64 [upgradable from: 5.15.0.41.44~20.04.13]
linux-image-generic-hwe-20.04/focal-security 5.15.0.43.46~20.04.14 amd64 [upgradable from: 5.15.0.41.44~20.04.13]
Let's look at one of the problematic packages by checking those versions at http://packages.ubuntu.com:
  • librsvg2-2 v2.48.2-1 is in focal
  • librsvg2-2 v2.48.9-1ubuntu0.20.04.1 is in focal-updates
Aha. Look carefully at your sources.
According to your apt update output, you have the focal and focal-security pockets of the Ubuntu repositories enabled.
But you're missing focal-updates
Re-enable that pocket, run another sudo apt update because your sources changed, and then try your install again.
user535733
  • 68,493
