The following command line and its output can help explain how it works.
$ LANG=C bash -c 'echo LANG=$LANG'; echo LANG=$LANG
LANG=C
LANG=sv_SE.UTF-8
LANG=C with only a space works only on the following command, after that the old LANG setting is used again.
But why does it print an empty value in your second case? I would explain it like this: The variable will be expanded by the shell directly. This is different from the case with bash -c 'echo LANG=$LANG', where the variable is protected [by the quotes] at first, and will be expanded later, when the previous variable set command has already been processed.
The method with only a space, no semicolon is often used, when you want to change language temporarily, as in the following example where the heading is changed to the standard language (English).
$ df -h
Filsystem Storlek Använt Ledigt Anv% Monterat på
udev 16G 0 16G 0% /dev
tmpfs 3,2G 1,6M 3,2G 1% /run
/dev/sda5 88G 32G 52G 39% /
tmpfs 16G 0 16G 0% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/sdb7 3,5T 998G 2,4T 30% /media/multimed-2
tmpfs 3,2G 20K 3,2G 1% /run/user/1000
$ LANG=C df -h
Filesystem Size Used Avail Use% Mounted on
