I supposedly enabled a root login by setting a password for root by means of the command:
sudo passwd root
Yet on the login screen after reboot when I use the username root the password I set earlier with the above command does not work. Should it?
Right now the only way I can be root is while logged in as user number 1000, and using the command:
sudo -i
OS is Ubuntu 22.04 Studio Jammy
