I am trying to install some programs, but I met with unmet dependencies. For example, sudo apt-get upgrade yields:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 linux-hwe-5.15-tools-5.15.0-41 : Depends: linux-tools-common but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
sudo apt --fix-broken install gives:
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  chromium-codecs-ffmpeg-extra gstreamer1.0-vaapi libclang-common-12-dev libclang-cpp12 libclang1-12 libfwupdplugin1 libgstreamer-plugins-bad1.0-0 libllvm11 libva-wayland2 llvm-12-tools
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  linux-tools-common
The following NEW packages will be installed:
  linux-tools-common
0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
2 not fully installed or removed.
Need to get 0 B/191 kB of archives.
After this operation, 845 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 206816 files and directories currently installed.)
Preparing to unpack .../linux-tools-common_5.4.0-122.138_all.deb ...
Unpacking linux-tools-common (5.4.0-122.138) ...
dpkg: error processing archive /var/cache/apt/archives/linux-tools-common_5.4.0-122.138_all.deb (--unpack):
 trying to overwrite '/usr/bin/acpidbg', which is also in package linux-intel-iotg-5.15-tools-common 5.15.0-1010.14~20.04.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
I have no idea how to fix this.
Roman
