I am trying to install apache2 by using sudo apt install apache2. I am getting error :
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: apache2 : Depends: apache2-utils (= 2.4.52-1ubuntu4.1) apache2-bin : Depends: libapr1 (>= 1.7.0) but it is not installable Depends: libaprutil1 (>= 1.6.0) but it is not installable Depends: libaprutil1-dbd-sqlite3 but it is not installable or libaprutil1-dbd-mysql but it is not installable or libaprutil1-dbd-odbc but it is not installable or libaprutil1-dbd-pgsql but it is not installable or libaprutil1-dbd-freetds but it is not installable Depends: libaprutil1-ldap but it is not installable Depends: liblua5.3-0 but it is not installable E: Unable to correct problems, you have held broken packages.
I am using Kubuntu 22.04
Edit :
I am also NOT able to install mysql-server
karel
  • 122,292
  • 133
  • 301
  • 332
