I have Ubuntu 21.04. It came with SNAP. Seems that has been left behind and how things work on flatpak.
I have some version of Handbrake installed but it is probably old, so I want to update it. I looked in the SNAP and it doesn't show as installed, and I would prefer to do it directly in case SNAP doesn't keep up with the latest release.
So I went down the "how to install flatpak" rabbit hole.
Looking here: https://flatpak.org/setup/Ubuntu
Then:
sudo add-apt-repository ppa:flatpak/stable
sudo apt update
sudo apt install flatpak
But the errors I see when doing this.
All 3 commands.
But errors start right away.
me@me-desktop:~/Downloads$ sudo add-apt-repository ppa:flatpak/stable
Repository: 'deb http://ppa.launchpad.net/flatpak/stable/ubuntu/ hirsute main'
Description:
Latest stable versions of Flatpak.
Support policy
This PPA is provided as a convenience for Ubuntu users, with no guarantee of support. If you are an Ubuntu developer and would like to volunteer to maintain packages for this PPA, please contact us via <https://github.com/flatpak/ppa-flatpak/issues>.
Packages in this PPA are built for the LTS branches of Ubuntu, currently focal, bionic and xenial. The newest LTS branch is treated as the highest priority for updates.
Branches that have reached EOL for non-subscription-based updates are likely to stop receiving updates, or be removed from this PPA, when backports to those branches become too difficult.
Non-LTS branches such as groovy and hirsute are not currently supported by this PPA. If you are an Ubuntu developer and would like to volunteer to maintain packages for this PPA, please contact us via <https://github.com/flatpak/ppa-flatpak/issues>.
Source code for the packages used here
- https://github.com/flatpak/ppa-flatpak
- https://github.com/flatpak/ppa-flatpak-builder
- https://github.com/flatpak/ppa-xdg-desktop-portal
- https://github.com/flatpak/ppa-xdg-desktop-portal-gtk
These packages are built from the ppa/stable/focal, ppa/stable/bionic, ppa/stable/xenial branches.
Development versions of these packages
https://launchpad.net/~flatpak/+archive/ubuntu/development provides newer prereleases of Flatpak from its development branch.
More info: https://launchpad.net/~flatpak/+archive/ubuntu/stable
Adding repository.
Press [ENTER] to continue or Ctrl-c to cancel.
Adding deb entry to /etc/apt/sources.list.d/flatpak-ubuntu-stable-hirsute.list
Adding disabled deb-src entry to /etc/apt/sources.list.d/flatpak-ubuntu-stable-hirsute.list
Adding key to /etc/apt/trusted.gpg.d/flatpak-ubuntu-stable.gpg with fingerprint 5C6D153A17C02C337EF6C663B8B9D41229DFA5F5
Ign:1 http://ftp.iinet.net.au/pub/ubuntu hirsute InRelease
Ign:2 http://ftp.iinet.net.au/pub/ubuntu hirsute-updates InRelease
Ign:3 http://ftp.iinet.net.au/pub/ubuntu hirsute-backports InRelease
Ign:4 http://ftp.iinet.net.au/pub/ubuntu hirsute-security InRelease
Err:5 http://ftp.iinet.net.au/pub/ubuntu hirsute Release
404 Not Found [IP: 150.101.135.3 80]
Err:6 http://ftp.iinet.net.au/pub/ubuntu hirsute-updates Release
Err:7 http://ftp.iinet.net.au/pub/ubuntu hirsute-backports Release
Err:8 http://ftp.iinet.net.au/pub/ubuntu hirsute-security Release
Ign:9 http://ppa.launchpad.net/flatpak/stable/ubuntu hirsute InRelease
Ign:10 http://ddebs.ubuntu.com hirsute InRelease
Err:11 http://ppa.launchpad.net/samoilov-lex/aftl-stable/ubuntu hirsute InRelease
403 Forbidden [IP: 185.125.190.52 80]
Ign:12 http://ddebs.ubuntu.com hirsute-updates InRelease
Ign:13 http://ddebs.ubuntu.com hirsute-proposed InRelease
Hit:14 http://ppa.launchpad.net/team-xbmc/ppa/ubuntu hirsute InRelease
Err:15 http://ddebs.ubuntu.com hirsute Release
404 Not Found [IP: 91.189.91.48 80]
Err:16 http://ppa.launchpad.net/flatpak/stable/ubuntu hirsute Release
404 Not Found [IP: 185.125.190.52 80]
Err:17 http://ddebs.ubuntu.com hirsute-updates Release
Err:18 http://ddebs.ubuntu.com hirsute-proposed Release
Reading package lists... Done
E: The repository 'http://ftp.iinet.net.au/pub/ubuntu hirsute Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ftp.iinet.net.au/pub/ubuntu hirsute-updates Release' no longer has a Release file.
E: The repository 'http://ftp.iinet.net.au/pub/ubuntu hirsute-backports Release' no longer has a Release file.
E: The repository 'http://ftp.iinet.net.au/pub/ubuntu hirsute-security Release' no longer has a Release file.
E: Failed to fetch http://ppa.launchpad.net/samoilov-lex/aftl-stable/ubuntu/dists/hirsute/InRelease 403 Forbidden [IP: 185.125.190.52 80]
E: The repository 'http://ppa.launchpad.net/samoilov-lex/aftl-stable/ubuntu hirsute InRelease' is not signed.
E: The repository 'http://ddebs.ubuntu.com hirsute Release' no longer has a Release file.
E: The repository 'http://ppa.launchpad.net/flatpak/stable/ubuntu hirsute Release' does not have a Release file.
E: The repository 'http://ddebs.ubuntu.com hirsute-updates Release' no longer has a Release file.
E: The repository 'http://ddebs.ubuntu.com hirsute-proposed Release' no longer has a Release file.
me@me-desktop:~/Downloads$ sudo apt update
Ign:11 http://ddebs.ubuntu.com hirsute-updates InRelease
Err:12 http://ppa.launchpad.net/samoilov-lex/aftl-stable/ubuntu hirsute InRelease
Err:16 http://ddebs.ubuntu.com hirsute-updates Release
Err:17 http://ppa.launchpad.net/flatpak/stable/ubuntu hirsute Release
me@me-desktop:~/Downloads$ sudo apt install flatpak
Building dependency tree... Done
The following packages were automatically installed and are no longer required:
kodi-visualization-spectrum libevent-core-2.1-7 libevent-pthreads-2.1-7 libopts25 sntp vlc-bin vlc-l10n vlc-plugin-access-extra
vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-splitter vlc-plugin-visualization
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libmalcontent-0-0 libostree-1-1
Suggested packages:
malcontent-gui
The following NEW packages will be installed:
flatpak libmalcontent-0-0 libostree-1-1
0 to upgrade, 3 to newly install, 0 to remove and 0 not to upgrade.
Need to get 1,446 kB of archives.
After this operation, 5,670 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 http://ftp.iinet.net.au/pub/ubuntu hirsute/universe amd64 libmalcontent-0-0 amd64 0.10.0-2
Err:2 http://ftp.iinet.net.au/pub/ubuntu hirsute/universe amd64 libostree-1-1 amd64 2020.8-2
Ign:3 http://ftp.iinet.net.au/pub/ubuntu hirsute-updates/universe amd64 flatpak amd64 1.10.2-1ubuntu1.1
Err:3 http://ftp.iinet.net.au/pub/ubuntu hirsute-updates/universe amd64 flatpak amd64 1.10.2-1ubuntu1.1
E: Failed to fetch http://ftp.iinet.net.au/pub/ubuntu/pool/universe/m/malcontent/libmalcontent-0-0_0.10.0-2_amd64.deb 404 Not Found [IP: 150.101.135.3 80]
E: Failed to fetch http://ftp.iinet.net.au/pub/ubuntu/pool/universe/o/ostree/libostree-1-1_2020.8-2_amd64.deb 404 Not Found [IP: 150.101.135.3 80]
E: Failed to fetch http://ftp.iinet.net.au/pub/ubuntu/pool/universe/f/flatpak/flatpak_1.10.2-1ubuntu1.1_amd64.deb 404 Not Found [IP: 150.101.135.3 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
So that isn't going to work.
--fix-missing gives similar errors.
Someone - please.
