There does not appear to be an equivalent setting for this dracut option in initramfs-tools.  One approach could be to remove kernel modules using a custom hook script.
Here is a rather simple example where I remove the e1000.ko and e1000e.ko kernel modules from the initramfs.
- confirm the modules are present in the initramfs initially.
root@ubuntu:~# lsinitramfs /boot/initrd.img-$(uname -r) | grep e1000
usr/lib/modules/5.15.0-48-generic/kernel/drivers/net/ethernet/intel/e1000
usr/lib/modules/5.15.0-48-generic/kernel/drivers/net/ethernet/intel/e1000/e1000.ko
usr/lib/modules/5.15.0-48-generic/kernel/drivers/net/ethernet/intel/e1000e
usr/lib/modules/5.15.0-48-generic/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko
- create a hookscript to remove the modules and rebuild the initramfs.
install -m 0755 /dev/null /etc/initramfs-tools/hooks/omit
cat <<'EOF' > /etc/initramfs-tools/hooks/omit
#!/bin/sh
PREREQ=""
prereqs()
   echo "$PREREQ"
case $1 in
prereqs)
   prereqs
   exit 0
esac
. /usr/share/initramfs-tools/hook-functions
Begin real processing below this line
OMIT_DRIVERS="e1000.ko e1000e.ko"
for i in ${OMIT_DRIVERS}; do
   find ${DESTDIR} -name ${i} -delete
done
EOF
update-initramfs -c -k $(uname -r)
- confirm the modules are not contained in the rebuilt initramfs.
The hook script could be much more flexible.  The contents of my sample are largely based on the examples in man -7 initramfs-tools.
There is a MODULES option in initramfs.conf that could also be useful.
