I am trying to install ubuntu 20.4 with cloud init, I would like to configure password for root so I tried this option but it didn't works. (vmware machine the login its form the consle)
UPDATE-
This option wroks for me. (Thanks Andrew Lowther)
user-data:
    chpasswd:
      list: |
      expire: false
      list:
        - root:$6$bababa
#cloud-config autoinstall: version: 1 apt: disable_components: [] geoip: true preserve_sources_list: false primary: - arches: - amd64 - i386 uri: http://archive.ubuntu.com/ubuntu - arches: - default uri: http://ports.ubuntu.com/ubuntu-ports identity: hostname: my-hostname password: $6$baagagagagaa$ewAe9SRZlS2q6yxYtvyJ0u.Lu4l6pgSf5uisgagajlOVTjBfuBb4QIQekfaToA1DtKAUCjoiiAEyc5VYj26uS1 realname: scadmin username: scadmin user-data: chpasswd: expire: false list: - root: $6$2mzNTlBmwfafad$0liKgagaoGfafafblalblalJQAbloalblalaFmw2m9fNXHHSZvw3zSfYH/sAA2P/kcTG8wruhLI6WWWzFaMiTEblHnfF8hQQPtxRs. kernel: package: linux-generic keyboard: layout: us toggle: null variant: '' locale: en_US.UTF-8 network: network: version: 2 ethernets: ens160: dhcp4: yes dhcp-identifier: mac ssh: allow-pw: true authorized-keys: [] install-server: true storage: config: - ptable: gpt path: /dev/sda wipe: superblock-recursive preserve: false name: '' grub_device: true type: disk id: disk-sda - device: disk-sda size: 1048576 flag: bios_grub number: 1 preserve: false grub_device: false type: partition id: partition-0 - device: disk-sda size: 30064771072 wipe: superblock flag: '' number: 2 preserve: false grub_device: false type: partition id: partition-1 - name: vg0 devices: - partition-1 preserve: false type: lvm_volgroup id: lvm_volgroup-0 - device: disk-sda size: 2144337920 wipe: superblock flag: '' number: 3 preserve: false grub_device: false type: partition id: partition-3 - fstype: ext4 volume: partition-3 preserve: false type: format id: format-0 - name: lv-swap volgroup: lvm_volgroup-0 size: 4294967296B wipe: superblock preserve: false type: lvm_partition id: lvm_partition-0 - name: lv-root volgroup: lvm_volgroup-0 size: 25765609472B wipe: superblock preserve: false type: lvm_partition id: lvm_partition-1 - fstype: ext4 volume: lvm_partition-1 preserve: false type: format id: format-3 - path: / device: format-3 type: mount id: mount-3 - fstype: swap volume: lvm_partition-0 preserve: false type: format id: format-4 - path: '' device: format-4 type: mount id: mount-4 - path: /boot device: format-0 type: mount id: mount-0 updates: security packages: - open-vm-tools late-commands: - | cat <<EOF > /target/etc/cloud/cloud.cfg.d/80_my.cfg hostname: $(openssl rand -hex 3) manage_etc_hosts: true preserve_hostname: false EOF
HELLBOY
  • 77
If you have an identity section then the users section does not get used. The users key also goes under the user-data key. See https://askubuntu.com/a/1385096/376778
You don't need to create the root user. You just need to set its password. I've used this partial user-data configuration to set the root password. This should work for local logins (e.g. vmware console) but additional configuration would be needed to allow remote logins (e.g. ssh).
#cloud-config
autoinstall:
  user-data:
    chpasswd:
      expire: false
      list:
        - root:$6$REDACTED
