OS: Ubuntu 22.04 LTS x86_64
I am trying to install MongoDB community edition from the official website. I was following the instructions but I am facing two problems.
The first: When running sudo apt-get update I get this at the bottom,
W: https://repo.mongodb.org/apt/ubuntu/dists/focal/mongodb-org/5.0/Release.gpg: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
The second: When Running sudo apt-get install -y mongodb-org
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: mongodb-org-mongos : Depends: libssl1.1 (>= 1.1.1) but it is not installable mongodb-org-server : Depends: libssl1.1 (>= 1.1.1) but it is not installable mongodb-org-shell : Depends: libssl1.1 (>= 1.1.1) but it is not installable E: Unable to correct problems, you have held broken packages.
It seems that the libssl version that is available on 22.04 is only version 3 https://packages.ubuntu.com/search?suite=jammy-updates&arch=any&searchon=names&keywords=libssl which seems to be unsupported by MongoDB, in addition, the installation instructions do not list 22.04 as supported, it seems you'll have to use another version or use the docker image: https://hub.docker.com/_/mongo
