I can't seem to create a .desktop launcher for the latest FreeCAD AppImage.
I first tried answer by @UriHerrera but it did not work. Then I included the answer by @vanadium but it did not work too. When I press Super+A keys, I can't see the FreeCAD icon there. Neither does FreeCad icon appears when I pressed the Super key and typed Freecad in search bar. I also tried refreshing gnome-shell by pressing Alt+F2followed by pressing r and Enter but this action did not help either.
Can you tell me my mistake?
Summarising my actions:
  1. I downloaded FreeCAD-0.20 from https://www.freecadweb.org/index.php into ~/.local/bin.
  2. Executed:
     $ chmod +x ~/.local/bin/FreeCAD-0.20.0-Linux-x86_64.AppImage
     $ ~/.local/bin/FreeCAD-0.20.0-Linux-x86_64.AppImage --appimage-extract
     $ cp ~/.local/bin/squashfs-root/freecad_weekly.desktop ~/.local/share/applications/freecad_weekly.desktop
     $ mkdir ~/.local/share/icons/FreeCAD/
     $ cp ~/.local/bin/squashfs-root/freecad_weekly.svg ~/.local/share/icons/FreeCAD/freecad_weekly.svg
     $ xprop | grep WM_CLASS
     WM_CLASS(STRING) = "gnome-terminal-server", "Gnome-terminal"
     $ gedit ~/.local/share/applications/freecad_weekly.desktop
  3. Changed
     [Desktop Entry]
     Version=1.0
     Name=FreeCAD Weekly
     Exec=AppRun
     Icon=freecad_weekly
     Type=Application
     Categories=Engineering;
     Comment=Feature based Parametric Modeler
     Terminal=false
     StartupNotify=true
     NoDisplay=false
     MimeType=application/x-extension-fcstd;
    to
     [Desktop Entry]
     Version=1.0
     Name=FreeCAD Weekly
     Exec=$HOME/.local/bin/FreeCAD-0.20.0-Linux-x86_64.AppImage
     Icon=$HOME/.local/share/icons/FreeCAD/freecad_weekly.svg
     StartupWMClass="gnome-terminal-server","Gnome-terminal"
     Type=Application
     Terminal=false
     StartupNotify=true
     NoDisplay=false
Also tried StartupWMClass=gnome-terminal-server Gnome-terminal but this did not work too.
Update: Why does the Freecad icon not show properly? freecad icon not showing
Outcome from updating ~/.local/share/applications/freecad_weekly.desktop to:
[Desktop Entry]
Version=1.0
Name=FreeCAD Weekly
Exec=freecad
Icon=freecad_weekly
Type=Application
Terminal=false
StartupNotify=true
NoDisplay=false
Sun Bear
  • 3,014
Almost there. Replace $HOME by the actual pathname. .desktop files do not know about bash variables.
Tips:
  • You can leave out the path names. Since ~/.local/bin is in your path, and .local/share/icons is a location where icons are searched, it is sufficient to just mention the file name of the executable, i.e., Exec=FreeCAD-0.20.0-Linux-x86_64.AppImage and the file name of the icon without the extension, i.e., Icon=freecad_weekly.
  • Personally, I would rather place the AppImage file in a directory "~/.apps" and create a symlink to it in ~/.local/bin, e.g. ln -s ~/.apps/FreeCAD-0.20.0-Linux-x86_64.AppImage ~/.local/bin/freecad. The line now becomes Exec=freecad. That way you can
    1. Run the program conveniently from the terminal using the command freecad.
    2. When you later download an updated appimage, it will be sufficient to recreate the link to have it point to the new version.
vanadium
  • 97,564
