I am trying to upgrade from Ubuntu 21.10 to Ubuntu 22.04. The notification to upgrade to 22.04 also came automatically. However upgradation did not work.
On trying to upgrade to LTS version using terminal, the following message is printed
$sudo do-release-upgrade
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading.
The sudo apt upgrade print the following message:
 The following packages have been kept back:
      cups cups-bsd cups-client cups-core-drivers cups-daemon cups-ipp-utils dirmngr ffmpeg gir1.2-javascriptcoregtk-4.0 gir1.2-webkit2-4.0 gnome-control-center gnome-control-center-data gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv ldap-utils libavcodec58 libavdevice58 libavfilter7 libavformat58 libavutil56 libcups2 libcupsimage2 libcurl3-gnutls libfreerdp2-2 libinput-bin libinput10 libjavascriptcoregtk-4.0-18 libldap-2.5-0 libpostproc55 libswresample3 libswscale5 libwebkit2gtk-4.0-37 libwinpr2-2 libxml2 ntfs-3g xserver-xephyr xserver-xorg-core xvfb xwayland
0 upgraded, 0 newly installed, 0 to remove and 47 not upgraded.
On trying to manually update or install any one of the above packages, it simply prints long list of dependency errors.
I do not how to resolve this. This problem has been asked quite a lot here at AskUbuntu but the solutions suggested did not work for me.
Is there any way to supress the error in these packages and move forward with upgrade to Ubuntu 22.04?
Update
The output of sudo apt update is as follows:
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:3 https://updates.signal.org/desktop/apt xenial InRelease
Reading package lists... Done
Building dependency tree... Done
47 packages can be upgraded. Run 'apt list --upgradable' to see them.
The output of sudo apt upgrade is as follows:
Calculating upgrade... Done
The list of external PPA's are as follows:
ppa:costales/yaru-colors-folder-color
ppa:linuxuprising/apps
ppa:numix/ppa
ppa:team-xbmc/ppa
ppa:kelebek333/mint-tools
The output of sudo apt full-upgrade is as follows:
  ldap-utils libavcodec58 libavformat58 libavutil56 libcups2 libcupsimage2 libcurl3-gnutls
0 upgraded, 0 newly installed, 0 to remove and 44 not upgraded.
Update (18 July 2022)
The output of apt-cache policy cups is as follows:
cups:
  Installed: 2.3.3op2-7ubuntu2
  Candidate: 2.4.1op1-1ubuntu4.1
  Version table:
     2.4.1op1-1ubuntu4.1 500
        500 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages
 *** 2.3.3op2-7ubuntu2 100
        100 /var/lib/dpkg/status
The output of apt-cache policy cups cups-daemon libcups2 is given below:
cups:
  Version table:
cups-daemon:
  Version table:
libcups2:
  Version table:
The output of sudo apt upgrade cups is given below:
The following packages have unmet dependencies: cups : Depends: cups-client (>= 2.4.1op1-1ubuntu4.1) Depends: cups-daemon (>= 2.4.1op1-1ubuntu4.1) Depends: libcups2 (= 2.4.1op1-1ubuntu4.1) but 2.3.3op2-7ubuntu2 is to be installed cups-core-drivers : Depends: cups-daemon (>= 2.4.1op1-1ubuntu4.1) Depends: libcups2 (= 2.4.1op1-1ubuntu4.1) but 2.3.3op2-7ubuntu2 is to be installed E: Broken packages
The output of apt-cache policy is given below:
Package files:
     release a=now
 500 https://updates.signal.org/desktop/apt xenial/main amd64 Packages
     release o=. xenial,a=xenial,n=xenial,l=. xenial,c=main,b=amd64
     origin updates.signal.org
 500 http://dl.google.com/linux/chrome/deb stable/main amd64 Packages
     release v=1.0,o=Google LLC,a=stable,n=stable,l=Google,c=main,b=amd64
     origin dl.google.com
 500 http://security.ubuntu.com/ubuntu jammy-security/multiverse i386 Packages
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=multiverse,b=i386
     origin security.ubuntu.com
 500 http://security.ubuntu.com/ubuntu jammy-security/multiverse amd64 Packages
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=multiverse,b=amd64
 500 http://security.ubuntu.com/ubuntu jammy-security/universe i386 Packages
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=universe,b=i386
 500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=universe,b=amd64
 500 http://security.ubuntu.com/ubuntu jammy-security/restricted i386 Packages
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=restricted,b=i386
 500 http://security.ubuntu.com/ubuntu jammy-security/restricted amd64 Packages
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=restricted,b=amd64
 500 http://security.ubuntu.com/ubuntu jammy-security/main i386 Packages
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=main,b=i386
     release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=main,b=amd64
Pinned packages:
Tanvir
  • 982
please make a backup from your personal data and make sure you have a installmedia for jammy just in case.
In /etc/apt/sources.list add jammy updates source.
sudo nano /etc/apt/sources.list
and add line
deb http://archive.ubuntu.com/ubuntu jammy-updates main restricted multiverse universe
then refresh
sudo apt update && apt -s -f install
the second part is only a similation. If apt nor dpkg are not complaining about errors.
sudo apt -f install && sudo apt full-upgrade
nobody
  • 5,792
