I just installed a fresh Windows 10 on my PC alongside with it I installed Ubuntu 22.04 LTS. My problem no is that it directly boots into Windows and I dont get the GNU GRUB Bootloader where i can decide which OS i want to use I can boot into ubuntu by hitting my BIOS key. The PC then asks me if i want to boot Windows or Ubuntu or enter setup. But i cant see a Solution where I can get the Bootloader. Maybe someone encountered the same issue before and can help me to fix it I would appreciate it.
Thanks
Dnns95
  • 19
First, please check your computer's bios has a UEFI or legacy EFI bootloader. You need to check the boot menu (F9, Esc, etc... depending on your PC manufacturer) and look for the Ubuntu Boot entry. If so, select it, you should see the grub menu and your computer should boot into Ubuntu. After that, you can change the boot order using the efibootmgr command with root (sudo) privileges. if not (the Ubuntu Boot menu does not show up), you have to use an Ubuntu live (cd or usb) and use the Boot-repair tool. Hope it helps you.
Look in your UEFI set-up and select boot options, there should be 3 options. One is Windows, two Ubuntu and the third is UEFI OS. You want to have this as the 1st Boot option. This will give you the boot manager at boot.
