I am in trouble reading a string from a file into another script as a string. Here is my detail:
I have 2 script file: one is 'step0.sh' and the other is 'step1.lsf'
'step0.sh' file contains only two lines
DIR="/sc/arion/work/kimm61/vepSIMUL/clinvar"
IN="clinvar.vcf"
and 'step1.lsf' contains those lines:
#!/bin/bash
#BSUB -J step1_1
#BSUB -P acc_Itan_lab
#BSUB -q private
#BSUB -n 41
#BSUB -R rusage[mem=20000]
#BSUB -R span[hosts=1]
#BSUB -W 120:00
#BSUB -o echo $DIR/step1out/%J.stdout
#BSUB -eo echo $DIR/step1out/%J.stderr
#BSUB -L /bin/bash
cd /sc/arion/work/kimm61/vepSIMUL/clinvar/ mkdir step1out
source activate phen ml bcftools/1.10.2 module load vep/100
source /sc/arion/work/kimm61/vepSIMUL/clinvar/step0.sh directory=echo "$DIR" input=echo "$IN" WRKDIR=echo "$DIR"/step1out ref_fasta=/sc/arion/projects/Itan_lab/vep_data/fasta_ref/Homo_sapiens.GRCh38.dna.primary_assembly.fa.gz
myinput=echo "$DIR"/"$IN" myoutput=vep1_1.vcf
(What I want)
  1. for the directory from 'step1.lsf', I would like to read 'DIR' from 'step0.sh'
  2. for the input from 'step1.lsf', I would like to read 'IN' from 'step0.sh'
  3. for the standard output(-o) and the standard err output(-eo), I would like to read'DIR' from 'step0.sh'
The proper and most simple way is to source the settings file in the beginning of the script. Then use the variables like as they were defined in the script. For Dash/Sh you must use the command ., for Bash you can use either source or ..
cat step1.lsf
#!/bin/bash
. step0.sh
echo "$DIR" echo "$IN"
If for some reason this is not that you want, you could parse the values of the variables from the settings file, capture the output by a command substitution $() and assign them to variables within the script. For example.
cat step1.lsf
#!/bin/bash
DIR="$(sed -nr 's/^DIR="(.)"$/\1/p' step0.sh)" IN="$(sed -nr 's/^IN="(.)"$/\1/p' step0.sh)"
Actually the problem in your script are the assignments like this:
Here you need to use command substitution to make it work.
directory="$(echo "$DIR")"
But in this case (where you are not processing the value in some special way) you can just assign the value of the variable $DIR to the other variable.
directory="$DIR"
pa4080
  • 30,621
