I have a Lenovo Legion 7 laptop with Nvidia RTX 2070 GPU and the brightness keys on the laptop do not change the brightness at all (it stays on max brightness it seems). I tried adding some parameters to grub settings that I found online but nothing seems to work so far.
Model: Lenovo Lenovo Legion 7 15IMH05
Memory: 32GB
Processor: Intel® Core™ i7-10750H CPU @ 2.60GHz × 12
Graphics: NVIDIA Corporation TU106BM [GeForce RTX 2070 Mobile]
Disk Capacity: 2.0 TB
OS Name: Ubuntu 22.04 LTS GNOME: 42.2 Windowing System: X11
I was partially able to solve this by creating a small shell script. It turns out that the the actual brightness is stored in /sys/class/backlight/acpi_video0/actual_brightness but for some reason the keys do not update the monitor brightness.
So I listen to the actual brightness using inotify and then I use xrandr to set the brightness for my laptop monitor (DP-4). You can find out what monitors you have connected using xrandr --current
You might want to tweak the math a little but other than that it seems to be working.
#!/bin/bash
while true do inotifywait -e modify /sys/class/backlight/acpi_video0/actual_brightness
read -r max < /sys/class/backlight/acpi_video0/max_brightness read -r actual < /sys/class/backlight/acpi_video0/actual_brightness
Will give .x brightness
brightness=echo &quot;scale=1; 100/$max*$actual/100&quot; | bc
xrandr --output DP-4 --brightness $brightness done
Here's my solution for my Lenovo laptop with NVIDIA RTX A2000 GPU: How to find an NVIDIA driver which works with your brightness function buttons.
Basically, you just need to install the latest-possible NVIDIA driver which doesn't have brightness-button bugs/regressions. I explain the full process in great detail.
Gabriel Staples
  • 11,502
  • 14
  • 97
  • 142
