I'm using ubuntu 20.04. I tried to install mongodb but can not. I tried some way but not effective. So I tried sudo apt update & sudo apt upgrade. But when I run upgrade, Terminal return
Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: mongodb-server : Depends: mongodb-server-core (>= 1:3.6.9+really3.6.8+90~g8e540c0b6d-0ubuntu5.3) but it is not installed Depends: mongodb-server-core (< 1:3.6.9+really3.6.8+90~g8e540c0b6d-0ubuntu5.3.1~) but it is not installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Then I run sudo apt --fix-broken install, still error.
***Reading package lists... Done
Correcting dependencies... Done
The following additional packages will be installed:
mongodb-server-core
The following NEW packages will be installed:
mongodb-server-core
0 upgraded, 1 newly installed, 0 to remove and 5 not upgraded.
9 not fully installed or removed.
Need to get 0 B/21,6 MB of archives.
After this operation, 77,8 MB of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 202200 files and directories currently installed.)
Preparing to unpack .../mongodb-server-core_1%3a3.6.9+really3.6.8+90~g8e540c0b6d-0ubuntu5.3_amd64.deb ...
Unpacking mongodb-server-core (1:3.6.9+really3.6.8+90~g8e540c0b6d-0ubuntu5.3) ...
dpkg: error processing archive /var/cache/apt/archives/mongodb-server-core_1%3a3.6.9+really3.6.8+90~g8e540c0b6d-0ubuntu5.3_amd64.deb (--unpa
ck):
trying to overwrite '/usr/bin/mongod', which is also in package mongodb-org-server 5.0.9-2
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
E: Sub-process /usr/bin/dpkg returned an error code (1)***
I also try remove mongodb in apt but it said E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Help me. Thanks
