at first, I go through any possible answer for this problem, nothing seems to work.
  1. I've download Mega https://mega.nz/desktop (22.06, Nautilus)
  2. Try to install it using software center, I have:
Unable to install nautilus-megasync: The following packages have unmett dependencies:
  1. Try same using terminal by:
    sudo dpkg -i nautilus-megasync-xUbuntu_22.04_amd64.deb
GIVES ME
Selecting previously unselected package nautilus-megasync.
(Reading database ... 195292 files and directories currently installed.)
Preparing to unpack nautilus-megasync-xUbuntu_22.04_amd64.deb ...
Unpacking nautilus-megasync (3.6.6) ...
dpkg: dependency problems prevent configuration of nautilus-megasync:
 nautilus-megasync depends on megasync; however:
  Package megasync is not installed.
dpkg: error processing package nautilus-megasync (--install): dependency problems - leaving unconfigured Processing triggers for libc-bin (2.35-0ubuntu3) ... Processing triggers for hicolor-icon-theme (0.17-2) ...
ALSO TRY:
apt install libcrypto++8 libc-ares2 libmediainfo0v5 libssl3
FINALLY what I've:
sudo apt install mega.deb
sudo dpkg -i mega.deb
(Reading database ... 211558 files and directories currently installed.)
Preparing to unpack mega.deb ...
Unpacking nautilus-megasync (3.6.6) over (3.6.6) ...
Please restart all running instances of Nautilus.
dpkg: error processing package nautilus-megasync (--install): dependency problems - leaving unconfigured Processing triggers for libc-bin (2.35-0ubuntu3) ... Processing triggers for hicolor-icon-theme (0.17-2) ... Errors were encountered while processing:
Any ideas what to do?
Install megasync first. You can download it from the same site.
You'll get megasync-xUbuntu_22.04_amd64.deb
Install it by sudo apt install ./megasync-xUbuntu_22.04_amd64.deb
After that you should be able to install the Nautilus extension.
Pilot6
  • 92,041
run terminal in the download directory and enter root su or use sudo
Then type:
dpkg -i megasync-xUbuntu_22.04_amd64.deb
Resilve the error with apt-get -f install
run sudo dpkg -i megasync-xUbuntu_22.04_amd64.deb
Now install the extension
Finaly run megasync to open it
if it doen't open run apt update then apt upgrade and apt --fix-broken install then pre 'y' to accept installation
