I am trying to install Lubuntu on a machine that has Ubuntu on it (BOTH LATEST VERSION)
When I boot with ISO disk it says loading Lubuntu for a long then it says: OK Finished Plymouth boot OK Finished Set Console scheme FAILED Failed to start Snap Daemon
Then the machine is locked up and I must turn it off to reboot
I used another Lununtu DVD but same result
Can you help me??????
Go to a login window: Alt-f2 Login with user lubuntu and no password. Check the journalctl as Juan suggests. After several failures my snapd had started successfully. But you can now restart it if it failed. Hit Alt-f1 and you may have a Gui running.
