My 20.04 PC has a 128GB SSD on which / is mounted.
I have an additional 1TB SSD for homes mounted at /home. All done in fstab which I'm fairly confident with.
/ (on /dev/sda2) is showing around 97% full in GParted and I know if this fills I'll have problems. (I'm assuming this is filling due to installing apps etc?).
What's a good way to prevent this happening? What would be a good directory on / to mount elsewhere? /var looks the largest at 29GB so should I move this to another disk (create a new partition on the 1TB?) and create a new mount point in fstab? If so, what's the best way to copy? just with cp or use rsync?
Or is there better way? I also have a 480GB SSD with two partitions I use for backups and VMs mounted at /mnt/bu & /mnt/vms which I guess I could re-purpose to hold all on /.
Thanks
~$ sudo du -smc /var/*
[sudo] password for roger:
7 /var/backups
196 /var/cache
1 /var/crash
29589 /var/lib
1 /var/local
0 /var/lock
1 /var/log
1 /var/mail
1 /var/metrics
13 /var/opt
0 /var/run
31 /var/snap
70 /var/spool
1 /var/tmp
518 /var/www
30421 total
sudo du -smc /* --exclude=/proc --exclude=/run
15 /bin
190 /boot
1 /cdrom
0 /dev
18 /etc
182861 /home
0 /initrd.img
0 /initrd.img.old
1489 /lib
1 /lib64
1 /lost+found
1 /media
1583995 /mnt
4294 /opt
1700 /root
14 /sbin
48696 /snap
1 /srv
2049 /swapfile
0 /sys
2 /tmp
9000 /usr
30421 /var
0 /vmlinuz
0 /vmlinuz.old
1864738 total
