I think I've damaged my Ubuntu installation, as now it is not recognising some terminal commands such as ufw/glances (which are already installed). The result is as follows.
-bash: ufw: command not found
Also sudo apt update --fix-missing is not not working, as it gives the following results.
Err:1 http://security.ubuntu.com/ubuntu focal-security InRelease
  Temporary failure resolving 'security.ubuntu.com'
Err:2 http://lk.archive.ubuntu.com/ubuntu focal InRelease
  Temporary failure resolving 'lk.archive.ubuntu.com'
Err:3 http://gb.archive.ubuntu.com/ubuntu bionic InRelease
  Temporary failure resolving 'gb.archive.ubuntu.com'
Err:4 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal InRelease
  Temporary failure resolving 'ppa.launchpad.net'
Err:5 http://lk.archive.ubuntu.com/ubuntu focal-updates InRelease
Err:6 http://ppa.launchpad.net/gluster/glusterfs-3.12/ubuntu focal InRelease
Err:7 http://lk.archive.ubuntu.com/ubuntu focal-backports InRelease
Err:8 http://ppa.launchpad.net/gluster/glusterfs-6/ubuntu focal InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: Failed to fetch http://lk.archive.ubuntu.com/ubuntu/dists/focal/InRelease  Temporary failure resolving 'lk.archive.ubuntu.com'
W: Failed to fetch http://lk.archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease  Temporary failure resolving 'lk.archive.ubuntu.com'
W: Failed to fetch http://lk.archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease  Temporary failure resolving 'lk.archive.ubuntu.com'W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease  Temporary failure resolving 'security.ubuntu.com'
W: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/dists/bionic/InRelease  Temporary failure resolving 'gb.archive.ubuntu.com'
W: Failed to fetch http://ppa.launchpad.net/deadsnakes/ppa/ubuntu/dists/focal/InRelease  Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/gluster/glusterfs-3.12/ubuntu/dists/focal/InRelease  Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/gluster/glusterfs-6/ubuntu/dists/focal/InRelease  Temporary failure resolving 'ppa.launchpad.net'
W: Some index files failed to download. They have been ignored, or old ones used instead.
This happened when I tried to downgrade the python version from 3.8 to 3.5 to run a specific programme, in ubuntu 20.2. I only saw the comments not recommending the procedures a little late, which was too late at the moment.
Couple of notes: my path is as follows (and it contains bin, /usr/bin and /usr/local/bin)
/home/chameera/.local/bin:/opt/lib/mpich/bin:/opt/lib/netcdf/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
  • using wget, cannot download any file, but can ssh into and out of the machine, as well as transfer files
  • ping to 8.8.8.8 responds, but doesn't respond to www.google.com
  • sudo dpkg --configure -a does not generate any output after clearing the lock files in sudo rm /var/lib/apt/lists/lock, sudo rm /var/lib/dpkg/lock, sudo rm /var/lib/dpkg/lock-frontend, sudo rm /var/lib/apt/lists/* -vf
I have not yet rebooted the machine as it is a remote machine and a little bit worried to do so, fearing that I may loose access to it again until I physically recover the machine. I would be so grateful if any of you can help me out in this regard.
Thank you so much in advance!
You need to undo your downgrade of python, I'm not sure how you did it.
After that is fixed, I would recommend either using Anaconda to manage other python versions (never touch system python!) or installing CPython separately in another directory tree, such as /opt/python/<version>. With the latter option, you can use Environment Modules or Lmod to swap software versions in and out easily, similarly to python virtual environments or conda environments.
jamie
