When I tried to install vlc on 22.04, I got the following error message:
libva-wayland2 : Depends: libva2 (< 2.13.0.1) but 2.14.0-1 is to be installed
Usually apt would install the required lib automatically, but this one doesn't.
Here is the sudo apt update message:
Ign:5 https://ppa.launchpadcontent.net/videolan/stable-daily/ubuntu jammy InRelease
Err:6 https://ppa.launchpadcontent.net/videolan/stable-daily/ubuntu jammy Release
404 Not Found [IP: 185.125.190.52 443]
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/videolan/stable-daily/ubuntu jammy Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
In addition, I tried install it with sudo snap install vlc, the installation is only partially successful. It can only open files from limited folder path. Several disks mounted cannot be open, and only the files in those original basic Linux folders and home folder can be open. I guess this is related with this libva problem.
