So I recently came across wsl and was trying to configure postgres with it but I am not able to do so, I am following these instruction - https://docs.microsoft.com/en-us/windows/wsl/tutorials/wsl-database but when I run the command: sudo apt install postgresql postgresql-contrib I receive this error -
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: postgresql : Depends: postgresql-13 but it is not going to be installed postgresql-contrib : Depends: postgresql-contrib-13 E: Unable to correct problems, you have held broken packages.
I have gone through some other answers related to this issue too and have tried running-
sudo aptitude install postgresql postgresql-contrib output:
The following NEW packages will be installed:
  libllvm6.0{a} libpq5{ab} postgresql postgresql-13{ab} postgresql-client-13{ab} postgresql-contrib sysstat{a}
0 packages upgraded, 7 newly installed, 0 to remove and 0 not upgraded.
Need to get 32.3 MB of archives. After unpacking 121 MB will be used.
 libpq5 : Depends: libssl1.0.0 (>= 1.0.2~beta3) which is a virtual package and is not provided by any available package
postgresql-13 : Depends: libicu55 (>= 55.1-1~) which is a virtual package and is not provided by any available package
postgresql-client-13 : Depends: libreadline6 (>= 6.0) which is a virtual package and is not provided by any available package
                    Depends: libssl1.0.0 (>= 1.0.0) which is a virtual package and is not provided by any available package
The following actions will resolve these dependencies:
 Keep the following packages at their current version:
  1. libpq5 [Not Installed]
  2. postgresql [Not Installed]
  3. postgresql-13 [Not Installed]
  4. postgresql-client-13 [Not Installed]
  5. postgresql-contrib [Not Installed]
Accept this solution? [Y/n/q/?] Y No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used.
how should I solve this? I am using windows11, wsl 2(ubuntu)
NotTheDr01ds
  • 22,082
This seems to be an issue with package handling in the GNU/Linux shell environment and not so much to do with WSL or PostgreSQL installation. I have only dealt with unmet dependencies in upgrades, but here is a thread showing the use of the 'f-option' that should help when it comes to these types of installs: How to automatically fetch missing dependencies when installing software from .deb?
