I recently just started using Linux and while trying to install Wine32 so that I could run .exe files like an article stated, It gives me an error like like this:
Reading package lists... Done
Building dependency tree... Done
apt : Depends: libapt-pkg6.0 (>= 2.4.5) but it is not going to be installed
Depends: libsystemd0 but it is not installable
bsdutils : PreDepends: libsystemd0 but it is not installable
init : PreDepends: systemd-sysv
shim-signed : Depends: grub-efi-amd64-signed but it is not going to be installed or
grub-efi-arm64-signed but it is not installable
Depends: grub2-common (>= 2.04-1ubuntu24)
util-linux : PreDepends: libsystemd0 but it is not installable
PreDepends: libudev1 (>= 183) but it is not installable
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I did some research already but nothing worked. Hopefully I would be able to get a working solution for this!
