I wanted to install the mtgap keyboard layout, so I go to the its github page
https://github.com/kenranunderscore/mtgap-layout
and do the following:
sudo cp xkb/mtgap_30 /usr/share/X11/xkb/symbols/
nano /usr/share/X11/xkb/rules/evdev.xml
(then add some content from the mtgap's documentation)
After that, I restart the computuer. And the mtgap layout is showing on the options of keyboard kayout to choose from. Everything work as expected.
But I want to change some key bindings in the layout (I want to change the binding from Caps lock -> Backspace into Caps lock -> Escape)
So I edit /usr/share/X11/xkb/symbols/mtgap_30 (replace "_bksp" -> "_esc", "BackSpace" -> "Escape")
I also edit the /usr/share/X11/xkb/rules/evdev.xml (replace "_bksp" -> "_esc")
After that, I restart computer, then I cannot login anymore
What I did to try to fix that:
  • Boot into a ubuntu live usb and edit the mtgap_30 and evdev.xml file
  • I also chroot and run: dpkg-reconfigure keyboard-configuration still can not fix it.
Can you help me to fix that?
Image of the login screen:
karel
  • 122,292
  • 133
  • 301
  • 332
