Here is the log:
[ 43368.158] X.Org X Server 1.21.1.3
X Protocol Version 11, Revision 0
[ 43368.158] Current Operating System: Linux housesparrow 5.15.0-39-generic #42-Ubuntu SMP Thu Jun 9 23:42:32 UTC 2022 x86_64
[ 43368.158] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-39-generic root=UUID=37507205-bfd0-40ee-8c7b-9d2f17d9f6ac ro
[ 43368.158] xorg-server 2:21.1.3-2ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[ 43368.158] Current version of pixman: 0.40.0
[ 43368.158]    Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
[ 43368.158] Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 43368.158] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul  5 18:50:49 2022
[ 43368.158] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 43368.158] (==) No Layout section.  Using the first Screen section.
[ 43368.158] (==) No screen section available. Using defaults.
[ 43368.158] (**) |-->Screen "Default Screen Section" (0)
[ 43368.158] (**) |   |-->Monitor "<default monitor>"
[ 43368.158] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[ 43368.158] (==) Automatically adding devices
[ 43368.158] (==) Automatically enabling devices
[ 43368.158] (==) Automatically adding GPU devices
[ 43368.158] (==) Automatically binding GPU devices
[ 43368.158] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 43368.158] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 43368.158]    Entry deleted from font path.
[ 43368.158] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 43368.158] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 43368.158] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 43368.158] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 43368.158] (==) FontPath set to:
    /usr/share/fonts/X11/misc,
    /usr/share/fonts/X11/Type1,
    built-ins
[ 43368.158] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 43368.158] (II) The server relies on udev to provide the list of input devices.
    If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 43368.158] (II) Loader magic: 0x55bf16b2b020
[ 43368.158] (II) Module ABI versions:
[ 43368.158]    X.Org ANSI C Emulation: 0.4
[ 43368.158]    X.Org Video Driver: 25.2
[ 43368.158]    X.Org XInput driver : 24.4
[ 43368.158]    X.Org Server Extension : 10.0
[ 43368.159] (--) using VT number 2
[ 43368.159] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 43368.159] (II) xfree86: Adding drm device (/dev/dri/card0) [ 43368.159] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0 [ 43368.160] (--) PCI:(0@0:2:0) 8086:9bc8:103c:8767 rev 3, Mem @ 0xb0000000/16777216, 0xa0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072 [ 43368.160] (II) LoadModule: "glx" [ 43368.160] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 43368.160] (II) Module glx: vendor="X.Org Foundation" [ 43368.160] compiled for 1.21.1.3, module version = 1.0.0 [ 43368.160] ABI class: X.Org Server Extension, version 10.0 [ 43368.160] (==) Matched modesetting as autoconfigured driver 0 [ 43368.160] (==) Matched fbdev as autoconfigured driver 1 [ 43368.160] (==) Matched vesa as autoconfigured driver 2 [ 43368.160] (==) Assigned the driver to the xf86ConfigLayout [ 43368.160] (II) LoadModule: "modesetting" [ 43368.160] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 43368.161] (II) Module modesetting: vendor="X.Org Foundation" [ 43368.161] compiled for 1.21.1.3, module version = 1.21.1 [ 43368.161] Module class: X.Org Video Driver [ 43368.161] ABI class: X.Org Video Driver, version 25.2 [ 43368.161] (II) LoadModule: "fbdev" [ 43368.161] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 43368.161] (II) Module fbdev: vendor="X.Org Foundation" [ 43368.161] compiled for 1.21.1.3, module version = 0.5.0 [ 43368.161] Module class: X.Org Video Driver [ 43368.161] ABI class: X.Org Video Driver, version 25.2 [ 43368.161] (II) LoadModule: "vesa" [ 43368.161] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so [ 43368.161] (II) Module vesa: vendor="X.Org Foundation" [ 43368.161] compiled for 1.21.1.3, module version = 2.5.0 [ 43368.161] Module class: X.Org Video Driver [ 43368.161] ABI class: X.Org Video Driver, version 25.2 [ 43368.161] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 43368.161] (II) FBDEV: driver for framebuffer: fbdev [ 43368.161] (II) VESA: driver for VESA chipsets: vesa [ 43368.161] xf86EnableIO: failed to enable I/O ports 0000-03ff (Operation not permitted) [ 43368.161] (II) modeset(0): using drv /dev/dri/card0 [ 43368.161] (WW) Falling back to old probe method for fbdev [ 43368.161] (II) Loading sub module "fbdevhw" [ 43368.161] (II) LoadModule: "fbdevhw" [ 43368.161] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 43368.161] (II) Module fbdevhw: vendor="X.Org Foundation" [ 43368.161] compiled for 1.21.1.3, module version = 0.0.2 [ 43368.161] ABI class: X.Org Video Driver, version 25.2 [ 43368.161] (EE) open /dev/fb0: No such file or directory [ 43368.161] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 43368.161] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 43368.161] (==) modeset(0): RGB weight 888 [ 43368.161] (==) modeset(0): Default visual is TrueColor [ 43368.161] (II) Loading sub module "glamoregl" [ 43368.161] (II) LoadModule: "glamoregl" [ 43368.161] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 43368.164] (II) Module glamoregl: vendor="X.Org Foundation" [ 43368.164] compiled for 1.21.1.3, module version = 1.0.1 [ 43368.164] ABI class: X.Org ANSI C Emulation, version 0.4 [ 43368.182] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CML GT2) [ 43368.182] (II) modeset(0): glamor initialized [ 43368.182] (==) modeset(0): VariableRefresh: disabled [ 43368.182] (==) modeset(0): AsyncFlipSecondaries: disabled [ 43368.193] (II) modeset(0): Output HDMI-1 has no monitor section [ 43368.193] (II) modeset(0): Output DP-1 has no monitor section [ 43368.205] (II) modeset(0): EDID for output HDMI-1 [ 43368.205] (II) modeset(0): EDID for output DP-1 [ 43368.205] (II) modeset(0): Output HDMI-1 disconnected [ 43368.205] (II) modeset(0): Output DP-1 disconnected [ 43368.205] (WW) modeset(0): No outputs definitely connected, trying again... [ 43368.205] (II) modeset(0): Output HDMI-1 disconnected [ 43368.205] (II) modeset(0): Output DP-1 disconnected [ 43368.205] (WW) modeset(0): Unable to find connected outputs - setting 1024x768 initial framebuffer [ 43368.205] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 43368.205] (==) modeset(0): DPI set to (96, 96) [ 43368.205] (II) Loading sub module "fb" [ 43368.205] (II) LoadModule: "fb" [ 43368.205] (II) Module "fb" already built-in [ 43368.205] (II) UnloadModule: "fbdev" [ 43368.205] (II) Unloading fbdev [ 43368.205] (II) UnloadSubModule: "fbdevhw" [ 43368.205] (II) Unloading fbdevhw [ 43368.205] (II) UnloadModule: "vesa" [ 43368.205] (II) Unloading vesa [ 43368.211] (==) modeset(0): Backing store enabled [ 43368.211] (==) modeset(0): Silken mouse enabled [ 43368.212] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 43368.212] (==) modeset(0): DPMS enabled [ 43368.212] (II) modeset(0): [DRI2] Setup complete [ 43368.212] (II) modeset(0): [DRI2] DRI driver: iris [ 43368.212] (II) modeset(0): [DRI2] VDPAU driver: va_gl [ 43368.212] (II) Initializing extension Generic Event Extension [ 43368.212] (II) Initializing extension SHAPE [ 43368.212] (II) Initializing extension MIT-SHM [ 43368.212] (II) Initializing extension XInputExtension [ 43368.212] (II) Initializing extension XTEST [ 43368.212] (II) Initializing extension BIG-REQUESTS [ 43368.212] (II) Initializing extension SYNC [ 43368.212] (II) Initializing extension XKEYBOARD [ 43368.212] (II) Initializing extension XC-MISC [ 43368.212] (II) Initializing extension SECURITY [ 43368.212] (II) Initializing extension XFIXES [ 43368.212] (II) Initializing extension RENDER [ 43368.212] (II) Initializing extension RANDR [ 43368.212] (II) Initializing extension COMPOSITE [ 43368.213] (II) Initializing extension DAMAGE [ 43368.213] (II) Initializing extension MIT-SCREEN-SAVER [ 43368.213] (II) Initializing extension DOUBLE-BUFFER [ 43368.213] (II) Initializing extension RECORD [ 43368.213] (II) Initializing extension DPMS [ 43368.213] (II) Initializing extension Present [ 43368.213] (II) Initializing extension DRI3 [ 43368.213] (II) Initializing extension X-Resource [ 43368.213] (II) Initializing extension XVideo [ 43368.213] (II) Initializing extension XVideo-MotionCompensation [ 43368.213] (II) Initializing extension SELinux [ 43368.213] (II) SELinux: Disabled on system [ 43368.213] (II) Initializing extension GLX [ 43368.218] (II) AIGLX: Loaded and initialized iris [ 43368.218] (II) GLX: Initialized DRI2 GL provider for screen 0 [ 43368.218] (II) Initializing extension XFree86-VidModeExtension [ 43368.218] (II) Initializing extension XFree86-DGA [ 43368.218] (II) Initializing extension XFree86-DRI [ 43368.218] (II) Initializing extension DRI2 [ 43368.218] (II) modeset(0): Damage tracking initialized [ 43368.239] (II) config/udev: Adding input device Power Button (/dev/input/event2) [ 43368.239] () Power Button: Applying InputClass "libinput keyboard catchall" [ 43368.239] (II) LoadModule: "libinput" [ 43368.239] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 43368.240] (II) Module libinput: vendor="X.Org Foundation" [ 43368.240] compiled for 1.20.14, module version = 1.2.1 [ 43368.240] Module class: X.Org XInput Driver [ 43368.240] ABI class: X.Org XInput driver, version 24.1 [ 43368.240] (II) Using input driver 'libinput' for 'Power Button' [ 43368.240] () Power Button: always reports core events [ 43368.240] () Option "Device" "/dev/input/event2" [ 43368.241] (II) event2 - Power Button: is tagged by udev as: Keyboard [ 43368.241] (II) event2 - Power Button: device is a keyboard [ 43368.241] (II) event2 - Power Button: device removed [ 43368.251] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2" [ 43368.251] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6) [ 43368.251] () Option "xkb_model" "pc105" [ 43368.251] () Option "xkb_layout" "us" [ 43368.251] () Option "xkb_variant" "dvorak-intl" [ 43368.262] (II) event2 - Power Button: is tagged by udev as: Keyboard [ 43368.262] (II) event2 - Power Button: device is a keyboard [ 43368.262] (II) config/udev: Adding input device Video Bus (/dev/input/event3) [ 43368.262] () Video Bus: Applying InputClass "libinput keyboard catchall" [ 43368.262] (II) Using input driver 'libinput' for 'Video Bus' [ 43368.262] () Video Bus: always reports core events [ 43368.262] () Option "Device" "/dev/input/event3" [ 43368.263] (II) event3 - Video Bus: is tagged by udev as: Keyboard [ 43368.263] (II) event3 - Video Bus: device is a keyboard [ 43368.263] (II) event3 - Video Bus: device removed [ 43368.319] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3/event3" [ 43368.319] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7) [ 43368.319] () Option "xkb_model" "pc105" [ 43368.319] () Option "xkb_layout" "us" [ 43368.319] () Option "xkb_variant" "dvorak-intl" [ 43368.321] (II) event3 - Video Bus: is tagged by udev as: Keyboard [ 43368.321] (II) event3 - Video Bus: device is a keyboard [ 43368.323] (II) config/udev: Adding input device Power Button (/dev/input/event1) [ 43368.323] () Power Button: Applying InputClass "libinput keyboard catchall" [ 43368.323] (II) Using input driver 'libinput' for 'Power Button' [ 43368.323] () Power Button: always reports core events [ 43368.323] () Option "Device" "/dev/input/event1" [ 43368.325] (II) event1 - Power Button: is tagged by udev as: Keyboard [ 43368.325] (II) event1 - Power Button: device is a keyboard [ 43368.325] (II) event1 - Power Button: device removed [ 43368.343] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1" [ 43368.343] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8) [ 43368.343] () Option "xkb_model" "pc105" [ 43368.343] () Option "xkb_layout" "us" [ 43368.343] () Option "xkb_variant" "dvorak-intl" [ 43368.345] (II) event1 - Power Button: is tagged by udev as: Keyboard [ 43368.345] (II) event1 - Power Button: device is a keyboard [ 43368.347] (II) config/udev: Adding input device Sleep Button (/dev/input/event0) [ 43368.347] () Sleep Button: Applying InputClass "libinput keyboard catchall" [ 43368.347] (II) Using input driver 'libinput' for 'Sleep Button' [ 43368.347] () Sleep Button: always reports core events [ 43368.347] () Option "Device" "/dev/input/event0" [ 43368.348] (II) event0 - Sleep Button: is tagged by udev as: Keyboard [ 43368.349] (II) event0 - Sleep Button: device is a keyboard [ 43368.349] (II) event0 - Sleep Button: device removed [ 43368.375] () Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0" [ 43368.375] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9) [ 43368.375] () Option "xkb_model" "pc105" [ 43368.375] () Option "xkb_layout" "us" [ 43368.375] () Option "xkb_variant" "dvorak-intl" [ 43368.377] (II) event0 - Sleep Button: is tagged by udev as: Keyboard [ 43368.377] (II) event0 - Sleep Button: device is a keyboard [ 43368.379] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event10) [ 43368.379] (II) No input driver specified, ignoring this device. [ 43368.379] (II) This device may have been added with another device file. [ 43368.380] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event11) [ 43368.380] (II) No input driver specified, ignoring this device. [ 43368.380] (II) This device may have been added with another device file. [ 43368.381] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event12) [ 43368.381] (II) No input driver specified, ignoring this device. [ 43368.381] (II) This device may have been added with another device file. [ 43368.382] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event13) [ 43368.382] (II) No input driver specified, ignoring this device. [ 43368.382] (II) This device may have been added with another device file. [ 43368.383] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event14) [ 43368.383] (II) No input driver specified, ignoring this device. [ 43368.383] (II) This device may have been added with another device file. [ 43368.384] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event5) [ 43368.384] (II) No input driver specified, ignoring this device. [ 43368.384] (II) This device may have been added with another device file. [ 43368.385] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event6) [ 43368.385] (II) No input driver specified, ignoring this device. [ 43368.385] (II) This device may have been added with another device file. [ 43368.385] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7) [ 43368.386] (II) No input driver specified, ignoring this device. [ 43368.386] (II) This device may have been added with another device file. [ 43368.386] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event8) [ 43368.386] (II) No input driver specified, ignoring this device. [ 43368.386] (II) This device may have been added with another device file. [ 43368.387] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event9) [ 43368.387] (II) No input driver specified, ignoring this device. [ 43368.387] (II) This device may have been added with another device file. [ 43368.393] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event4) [ 43368.393] () HP WMI hotkeys: Applying InputClass "libinput keyboard catchall" [ 43368.393] (II) Using input driver 'libinput' for 'HP WMI hotkeys' [ 43368.393] () HP WMI hotkeys: always reports core events [ 43368.393] () Option "Device" "/dev/input/event4" [ 43368.395] (II) event4 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch [ 43368.395] (II) event4 - HP WMI hotkeys: device is a keyboard [ 43368.395] (II) event4 - HP WMI hotkeys: device removed [ 43368.439] () Option "config_info" "udev:/sys/devices/virtual/input/input4/event4" [ 43368.439] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 10) [ 43368.439] () Option "xkb_model" "pc105" [ 43368.439] () Option "xkb_layout" "us" [ 43368.439] (*) Option "xkb_variant" "dvorak-intl" [ 43368.441] (II) event4 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch [ 43368.441] (II) event4 - HP WMI hotkeys: device is a keyboard
There is no other error in the terminal. My server is a repurposed Desktop computer that used to work fine.
I ran startx as root on Ubuntu 22.
