You may already figured out the answer, but I will add my musings here: one needs to append the package version fully as you saw them in your query, and, in this case we also need to include the mariadb 10.3.22 client package dependencies, in a format like this (as on April 12th, 2023):
apt install mariadb-server-10.3=1:10.3.22-1ubuntu1 mariadb-server-core-10.3=1:10.3.22-1ubuntu1 mariadb-client-10.3=1:10.3.22-1ubuntu1 mariadb-client-core-10.3=1:10.3.22-1ubuntu1
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
libxmlb1
Use 'apt autoremove' to remove it.
The following additional packages will be installed:
galera-3 libcgi-fast-perl libcgi-pm-perl libconfig-inifiles-perl libdbd-mysql-perl libdbi-perl libencode-locale-perl libfcgi-perl libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl libhttp-date-perl libhttp-message-perl
libio-html-perl liblwp-mediatypes-perl libsnappy1v5 libterm-readkey-perl libtimedate-perl liburi-perl mariadb-common socat
Suggested packages:
libclone-perl libmldbm-perl libnet-daemon-perl libsql-statement-perl libdata-dump-perl libipc-sharedcache-perl libwww-perl mailx mariadb-test tinyca
The following NEW packages will be installed:
libio-html-perl liblwp-mediatypes-perl libsnappy1v5 libterm-readkey-perl libtimedate-perl liburi-perl mariadb-client-10.3 mariadb-client-core-10.3 mariadb-common mariadb-server-10.3 mariadb-server-core-10.3 socat
0 upgraded, 25 newly installed, 0 to remove and 61 not upgraded.
Need to get 29.7 MB of archives.
After this operation, 222 MB of additional disk space will be used.
Do you want to continue? [Y/n]
I hope it helps, and no worries, it took me a dozen of minutes to figure out the correct versions for Ubuntu focal ;-)
lsb_release -a
Description: Ubuntu 20.04.5 LTS
Release: 20.04
Codename: focal
