I tried to install MSSQL-Server using Microsoft's guide but I get this error during the installation, I tried Synaptic but it did not work, I browsed trough Stackexchange running some terminal codes but it did not help either, here is the error:
The following packages have unmet dependencies: mssql-server : Depends: libldap-2.4-2 but it is not installable E: Unable to correct problems, you have held broken packages.
And here is the other error when I try to update:
dpkg: error processing package msodbcsql17 (--configure):
 installed msodbcsql17 package post-installation script subprocess returned erro
r exit status 127
dpkg: dependency problems prevent configuration of mssql-tools:
 mssql-tools depends on msodbcsql17 (>= 17.3.0.0); however:
  Package msodbcsql17 is not configured yet.
dpkg: error processing package mssql-tools (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup erro r from a previous failure. Errors were encountered while processing: msodbcsql17 mssql-tools E: Sub-process /usr/bin/dpkg returned an error code (1)
I apologize if its too long.
karel
  • 122,292
  • 133
  • 301
  • 332
Ubuntu 22.04 broke compatibility. Libldap is no longer in apt or snap, you have to find it somewhere else. I run 22.04 and have th
