I encountered an issue where, after a routine apt-get upgrade, slack i.e. slack-desktop refused to open, with no real indication why from the logs.
After trying most of the solutions from this older post I ended update manually downloading the deb as indicated in my answer below....
FYI version 4.27.154 caused the failure to start.
In my search for an older version to roll back to, I ended up scouring the flathub code for a url for downloading an older .deb and came across:
https://downloads.slack-edge.com/releases/linux/$version/prod/x64/slack-desktop-$version-amd64.deb
Replacing the $version with a version number found on the slack release notes page did the trick.
Example:
wget https://downloads.slack-edge.com/releases/linux/4.26.1/prod/x64/slack-desktop-4.26.1-amd64.deb
and then
sudo dpkg -i slack-desktop-4.26.1-amd64.deb
UPDATE: I could have probably saved a lot of trouble by following the dowgrade path for flatpak apps.
