I have a very similar situation to the question Internal laptop screen not detected when using Nvidia driver --I am running Ubuntu 20.04 LTS on a laptop with dual intel and nvidia GPUs, and dual-booting the system together with Windows 11. Similarly, my boot-sequence is displayed on the laptop, including the grub menu. However, once I hit the login screen, my laptop display becomes completely black (but not off), and the OS only loads on the external monitor. Notably, if the external monitor is not connected, ubuntu just keeps showing me the startup screen.
I've tried doing all of the things described in the answers to that question--resetting xorg.conf from the default, resetting the file to an empty one, deleting the files altogether, etc. However, nothing has changed for me. Is there something else I can do here?
Potentially relevant data, as in the other question:
Output of lshw -C video:
*-display
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=nvidia latency=0 mode=2560x1440 visual=truecolor xres=2560 yres=1440
resources: iomemory:600-5ff iomemory:620-61f irq:175 memory:5f000000-5fffffff memory:6000000000-61ffffffff memory:6200000000-6201ffffff ioport:4000(size=128) memory:60000000-6007ffff
*-display
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: iomemory:620-61f iomemory:400-3ff irq:174 memory:622c000000-622cffffff memory:4000000000-400fffffff ioport:5000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
Output of xrandr:
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 698mm x 392mm
2560x1440 59.95*+ 74.96
3840x2160 29.97 25.00 23.98
1920x1080 75.00 60.00 59.94 50.00 29.97
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 60.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-4 disconnected (normal left inverted right x axis y axis)
Here's my current xorg.conf (though I've tried resetting it, blanking it, deleting it as well):
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 510.47.03
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
and nvidia-smi:
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 On | N/A |
| N/A 49C P8 18W / N/A | 842MiB / 8192MiB | 1% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1411 G /usr/lib/xorg/Xorg 53MiB |
| 0 N/A N/A 2018 G /usr/lib/xorg/Xorg 167MiB |
| 0 N/A N/A 2188 G /usr/bin/gnome-shell 121MiB |
| 0 N/A N/A 2641 G /usr/lib/firefox/firefox 482MiB |
| 0 N/A N/A 4011 G gnome-control-center 2MiB |
and prime-select query returns nvidia.
