If you do not have access to the most recent cpupower, or even if you do, you can just use the basic commands to make changes to the operating parameters of the CPU frequency scaling driver:
Examples:
Just look at what is available:
doug@s19:~/kernel/linux$ grep . /sys/devices/system/cpu/cpu0/cpufreq/*
/sys/devices/system/cpu/cpu0/cpufreq/affected_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/base_frequency:4100000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq:4800000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq:800000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency:20000
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences:default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference:balance_performance
/sys/devices/system/cpu/cpu0/cpufreq/related_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors:conservative ondemand userspace powersave performance schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:800000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:intel_cpufreq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:4800000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:800000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed:<unsupported>
O.K. I would rather use the ondemand CPU frequency scaling governor, so change it and then check it:
doug@s19:~/kernel/linux$ echo ondemand | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
ondemand
doug@s19:~/kernel/linux$ grep . /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu10/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu11/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu4/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu5/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu6/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu7/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu8/cpufreq/scaling_governor:ondemand
/sys/devices/system/cpu/cpu9/cpufreq/scaling_governor:ondemand
I think I would like to limit my max CPU frequency, so change it and check it:
doug@s19:~/kernel/linux$ echo 4400000 | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_max_freq
4400000
doug@s19:~/kernel/linux$ grep . /sys/devices/system/cpu/cpu*/cpufreq/scaling_max_freq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu10/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu11/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu5/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu6/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu7/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu8/cpufreq/scaling_max_freq:4400000
/sys/devices/system/cpu/cpu9/cpufreq/scaling_max_freq:4400000
I wonder if the frequency is actually limiting? put a heavy load on the CPUs and then check:
/scaling_cur_freq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:4399985
/sys/devices/system/cpu/cpu10/cpufreq/scaling_cur_freq:4400002
/sys/devices/system/cpu/cpu11/cpufreq/scaling_cur_freq:4400022
/sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq:4399980
/sys/devices/system/cpu/cpu2/cpufreq/scaling_cur_freq:4400004
/sys/devices/system/cpu/cpu3/cpufreq/scaling_cur_freq:4400007
/sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq:4399988
/sys/devices/system/cpu/cpu5/cpufreq/scaling_cur_freq:4400017
/sys/devices/system/cpu/cpu6/cpufreq/scaling_cur_freq:4399985
/sys/devices/system/cpu/cpu7/cpufreq/scaling_cur_freq:4400003
/sys/devices/system/cpu/cpu8/cpufreq/scaling_cur_freq:4400006
/sys/devices/system/cpu/cpu9/cpufreq/scaling_cur_freq:4399997
I think I would like to go back to max CPU frquency:
doug@s19:~/kernel/linux$ echo 4800000 | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_max_freq
4800000
doug@s19:~/kernel/linux$ grep . /sys/devices/system/cpu/cpu*/cpufreq/scaling_cur_freq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:4800002
/sys/devices/system/cpu/cpu10/cpufreq/scaling_cur_freq:4799995
/sys/devices/system/cpu/cpu11/cpufreq/scaling_cur_freq:4799998
/sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq:4800010
/sys/devices/system/cpu/cpu2/cpufreq/scaling_cur_freq:4800016
/sys/devices/system/cpu/cpu3/cpufreq/scaling_cur_freq:4799994
/sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq:4799987
/sys/devices/system/cpu/cpu5/cpufreq/scaling_cur_freq:4800012
/sys/devices/system/cpu/cpu6/cpufreq/scaling_cur_freq:4800000
/sys/devices/system/cpu/cpu7/cpufreq/scaling_cur_freq:4799985
/sys/devices/system/cpu/cpu8/cpufreq/scaling_cur_freq:4800022
/sys/devices/system/cpu/cpu9/cpufreq/scaling_cur_freq:4799989
