Because my umpc handles suspend/hibernation poorly, I've had to script a shutdown after timed idle.
The main script:
#!/bin/bash
idletime=$((15601000)) # 15 min in milliseconds #idletime=$((520330)) # about one minute, for testing idle=0 while [ $idle -lt $idletime ];do
idle=xprintidle sleep 1 done /home/jake/Scripts_Icons/Word_Shutdown sleep 2 sudo shutdown -P now
The Word_Shutdown script:
#!/bin/bash
if test $(wmctrl -l | grep "Microsoft Word" 2>&1 | wc -l) -eq 1; then
wmctrl -a "Microsoft Word"
sleep .2
xdotool keydown 0xffea + key 4
sleep .2
xdotool keyup 0xffea
sleep .2
xdotool key y fi
It works, but in order to monitor the battery life properly, I would like my uptimes during the sessions on one battery charge to be combined into one uptime.
Is that possible? I see that tuptime will show the uptime of the previous session and start monitoring the uptime of the current session. Is there a way to combine these outputs into a single readout eg 3hr 4 min ?
The tuptime command output:
[jake@P3 ~]$  sudo tuptime -S 2
System startups:    8  since  06:14:53 PM 06/20/2022
System shutdowns:   0 ok  +  7 bad
System life:            17h 50m 4s
System uptime: 16.15% = 2h 52m 46s System downtime: 83.85% = 14h 57m 18s
Average uptime: 21m 36s Average downtime: 2h 8m 11s
Current uptime: 2h 9m 1s since 09:55:56 AM 06/21/2022
The "System uptime" apparently combines all uptimes between shutdowns.
I have tried:
tuptime | awk -F'=' '/System uptime:/ {print $2}'
It works but, prints the seconds and the leading space as well i.e 2h 52m 46s. Is there a way to cut the seconds and the leading white space, leaving just the hours and minutes i.e. 2h 52m?
Or does uptime itself have a handle that can similarly jiggled?
Raffa
  • 34,963
jakfish
  • 23
In order to monitor the battery life properly:
  • Identify your battery's device reference(name) with upower -e like so:
    upower -e | grep -i "batt"
  • Get battery information by using upower -i with the reference(name) of your battery like so:
    upower -i /org/freedesktop/UPower/devices/battery_BAT0
  • Refine the upower -i output to get only state like so:
    awk '/state:/ {print $2}' <(upower -i /org/freedesktop/UPower/devices/battery_BAT0)
  • Refine the upower -i output to get only percentage without "%" like so:
    awk '/percentage:/ {print 0+$2}' <(upower -i /org/freedesktop/UPower/devices/battery_BAT0)
  • Use the above knowledge in a script that checks every five minutes to run your shutdown command (replace # Your shutdown command here with your actual command) when your battery charge reaches 8% or less while it is in the discharging state like so:
#!/bin/bash
while true; do state="$(awk '/state:/ {print $2}' <(upower -i /org/freedesktop/UPower/devices/battery_BAT0))" percentage="$(awk '/percentage:/ {print 0+$2}' <(upower -i /org/freedesktop/UPower/devices/battery_BAT0))" [ "$state" == "discharging" ] && [ "$percentage" -le "8" ] && # Your shutdown command here sleep 300 done
The main script:
#!/bin/bash ...
  • Your main script uses back ticks `...` for command substitution:
    idle=`xprintidle`
    While it will still work, back ticks for command substitution is considered a legacy feature(old and might get deprecated in the future) in bash so I recommend using $(...) instead like so:
    idle=$(xprintidle)
  • The sleep 1 call is too short for such uncritical task ... so I recommend extending it to say 30 seconds or even one minute like so:
    sleep 1m
#!/bin/bash ...
  • Your Word_Shutdown script has two issues in this part:
    First, you don't need to use grep "Microsoft Word" 2>&1 | wc -l ... grep -c "Microsoft Word" 2>&1 will output the same result.
    Second, quote the command substitution used directly in the if evaluation part to prevent possible word splitting like so:
    if test "$(wmctrl -l | grep -c "Microsoft Word" 2>&1)" -eq 1; then
I have tried:
Yes, and even better and future proof( e.g. if System uptime contains more than 3 fields e.g. 4d 22h 31m 54s) like so:
tuptime | awk '/System uptime:/  {for (i=1; i < NF; i++) {if (i > 4) {if (i < (NF - 1)) printf("%s ", $i); else print $i}}}'
That is correct.
Maybe, the -s option will become handy in your case ... from man tuptime:
-s | --seconds Output time in seconds and epoch
Raffa
  • 34,963
Tuptime could narrow the range in their reports. As you need the current and just the previous one, use tuptime -S -1, check it that is right with table output -t.
And to calculate both uptimes together:
tuptime -S -1 --csv | grep 'System uptime' | cut -d\" -f6 | awk -F\m '{print $1"m"}'
Use the Tuptime csv output to parse it easily, match the target line, cut the field and extract the text before 'm'.
rfmoz
  • 156
