Recently I had to reinstall Ubuntu. After returning to Ubuntu 22.04 I restored my /usr/local/ and var folders which caused huge mess in terms of packages being written as installed although when one tries to type the command in terminal they don't seem installed.
Normally I follow the advice from here and it fixes the mess but this time I think I made a bigger mess. As Pinta could not be installed due to mono-runtime not configured I removed them both from the system. Now mono-runtime seems to be installed but not configured: when I type sudo apt install mono-runtime I get
Reading package lists... Done
Building dependency tree... Done
mono-runtime is already the newest version (6.8.0.105+dfsg-3.2).
mono-runtime set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
but then when I type Y I get
Setting up mono-runtime (6.8.0.105+dfsg-3.2) ...
update-alternatives: error: alternative path /usr/bin/mono doesn't exist
dpkg: error processing package mono-runtime (--configure):
 installed mono-runtime package post-installation script subprocess returned error exit status 2
dpkg: dependency problems prevent configuration of libmono-i18n4.0-cil:
 libmono-i18n4.0-cil depends on mono-runtime (>= 6.8.0.105); however:
  Package mono-runtime is not configured yet.
 libmono-i18n4.0-cil depends on mono-runtime (<< 6.8.0.106); however:
dpkg: error processing package libmono-i18n4.0-cil (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libmono-i18n-west4.0-cil: libmono-i18n-west4.0-cil depends on libmono-i18n4.0-cil (>= 4.0.0~alpha1); however: Package libmono-i18n4.0-cil is not configured yet.
dpkg: error processing package libmono-i18n-west4.0-cil (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libmono-corlib4.5-cil: libmono-corlib4.5-cil depends on mono-runtime (>= 6.8.0.105); however: Package mono-runtime is not configured yet. libmono-corlib4.5-cil dependNo apport report written because the error message indicates its a followup error from a previous failure. No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because MaxReports is reached already s on mono-runtime (<< 6.8.0.106); however: Package mono-runtime is not configured yet.
dpkg: error processing package libmono-corlib4.5-cil (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: mono-runtime libmono-i18n4.0-cil libmono-i18n-west4.0-cil libmono-corlib4.5-cil
Does anybody has the slightest idea how to solve this problem without formatting the system all over again?
