Relevant info: Octave version...5.2.0 pkgs used: io-2.6.2 tablicious-0.3.5
Ubuntu version- 20.04.4 LTS
Hi! I'm reading timestamp and temperature data from an xlsx spreadsheet into Octave. I'm running into an interesting issue however. I'm able to plot the data, with the dateticks, and temperature data (markers) in the correct locations. Interestingly the (Line) seems to be close, but not actually connecting the markers. I'm not sure if I'm missing something silly, or experiencing a bug. Thanks so much! enter image description here enter image description here
clear all;
clc;
pkg load tablicious;
pkg load io;
[a,b]=xlsread('D10000007266C941_011522.xlsx','D10000007266C941_011522','A21:A221'); temp=xlsread('D10000007266C941_011522.xlsx','D10000007266C941_011522','C21:C221');
% The code above successfully read dates into octave!
date=datenum([a,b],'mm/dd/yy HH:MM:SS PM');
timeformat='mm/dd/yy';
figure(1)
grid on;
hold on;
plot (date,temp, "linestyle",'-',"marker",'o',"color",'b');
datetick ('x',timeformat,'keeplimits');
set(gca, 'linewidth', 2)
Mik
  • 31
So it appears to be a limitation of the OpenGL graphics toolkit. It lacks precision!! Oh dear... The following link explains it better than I will here, so I wont waste anyone's time.
https://docs.octave.org/v7.1.0/Precision-issues.html
See the following results of a "work around"..
The bad
The Much improved results! Don't you worry, its only 2000 years off...hee hee enter image description here
Mik
  • 31
