I just installed a new Intel 330 60 GB SSD into my HP Mini 2140 laptop.
But it's not going as fast as expected and my hdparm results aren't looking very good compared to SSD benchmarks at:
My results and info are below.
hdparm results:
justin@justin-HP-2140:~$ sudo hdparm -Tt /dev/sda
/dev/sda:
Timing cached reads: 1130 MB in 2.00 seconds = 564.50 MB/sec
Timing buffered disk reads: 372 MB in 3.01 seconds = 123.53 MB/sec
hdparm info:
justin@justin-HP-2140:~$ sudo hdparm -I /dev/sda
/dev/sda:
ATA device, with non-removable media
Model Number: INTEL SSDSC2CT060A3
Serial Number: CVMP215107WW060AGN
Firmware Revision: 300i
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
Used: unknown (minor revision code 0x0110)
Supported: 9 8 7 6 5
Likely used: 9
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 117231408
LBA48 user addressable sectors: 117231408
Logical Sector size: 512 bytes
Physical Sector size: 512 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 57241 MBytes
device size with M = 1000*1000: 60022 MBytes (60 GB)
cache/buffer size = unknown
Nominal Media Rotation Rate: Solid State Device
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: 128
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
* 48-bit Address feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
* WRITE_UNCORRECTABLE_EXT command
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* unknown 76[14]
* DMA Setup Auto-Activate optimization
Device-initiated interface power management
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Data Tables (AC5)
* Data Set Management TRIM supported (limit 1 block)
* Deterministic read data after TRIM
Security:
Master password revision code = 65534
supported
not enabled
not locked
frozen
not expired: security count
supported: enhanced erase
4min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5001517bb28c2593
NAA : 5
IEEE OUI : 001517
Unique ID : bb28c2593
Checksum: correct
In the HP Mini 2140 BIOS there are 2 options that from some other issues may have an impact:
- SATA : Enable/Disable
- Dual Core/CPU support: Enable/Disable
Both of these are enabled my default. If i disable SATA then the hdparm results show it is twice as slow.
Has anyone experienced slow SSD? Or seen an issue with the HD config? Or know how to fix this to get speeds that a new generation SSD should be capable of?
Note that this is with a fresh install on 12.04 LTS.
Note: by slow i mean 20 second boot to desktop (no login), 5 seconds to start terminal - was hoping that with ssd starting apps would be 1 sec
update: - thanks for all the answers - have applied TRIM and noop - helps a bit - but think the main problem as identified by john is the limitation of hp mini :(
