I would like to know where and how "To Do" stores the lists, but the burger menu is disabled and it (gnome-todo) does not even have a --version option. But here it is:
~$ apt show gnome-todo
Package: gnome-todo
Version: 3.28.1-6ubuntu1
There is no man page.
I don't see any further info on its homepage either:
Nor in the project wiki:
There is an old (2y) issue about the lack of documentation, not a single comment from the maintainers:
handle
  • 393
I found the local storage: /home/<user>/.local/share/evolution/tasks/<id>/tasks.ics and /home/<user>/.local/share/evolution/tasks/system/tasks.ics for "Personal"
Running $ gnome-todo -d prints
23:28:38.0742       GtdProviderSelector:    DEBUG: Adding provider local
23:28:38.0761            GtdProviderEds:    DEBUG: Task list 'Personal' successfully connected
23:28:38.0761            GtdProviderEds:    DEBUG: Task list 'test' successfully connected
23:28:38.0818            GtdTaskListEds:    DEBUG: ECalClientView for tasklist 'Personal' successfully acquired
23:28:38.0819            GtdTaskListEds:    DEBUG: ECalClientView for tasklist 'test' successfully acquired
23:28:38.0833            GtdTaskListEds:    DEBUG: Personal: GNOME To Do API version 1
23:28:38.0837            GtdTaskListEds:    DEBUG: test: GNOME To Do API version 1
Searching for https://github.com/GNOME/gnome-todo/search?q=%22Adding+provider%22 leads to https://github.com/GNOME/gnome-todo/blob/master/src/gui/gtd-provider-selector.c#L273
If you dig around, there should be several more "providers", e.g. "todo.txt", so I assume this is a buggy package.
Edit
Also see https://askubuntu.com/a/1272813/1029310
/home/<user>/.config/evolution/sources/system-task-list.source contains the configuration of the "Personal" task list.
Edit
The other "providers" are disabled by default and would require building from source. See https://askubuntu.com/a/1415059/1029310
handle
  • 393
