I was sent a file to run to help setup my environment to work on my companies network but after making it executable I keep running into this error regarding a curly brace and it wanting then, I have tried adding then where it says that it wants it to no avail . Here is the code I am trying to execute It would be a godsend if somebody could correct it
echo "Setting up /etc/environment with proxy settings"
if ! grep -q proxy /etc/environment; then echo "Setting proxy system-wide" { echo "http_proxy="http://proxy.cat.com:80/"" echo "https_proxy="http://proxy.cat.com:80/"" echo "ftp_proxy="http://proxy.cat.com:80/"" echo "socks_proxy="http://proxy.cat.com:80/"" echo "no_proxy=localhost,127.0.0.0/8,::1,cat.com,*.cat.com,165.26.78.0/23" } >> /etc/environment echo "Setting proxy for this session" export http_proxy=http://proxy.cat.com:80/ export https_proxy=http://proxy.cat.com:80/ export ftp_proxy=http://proxy.cat.com:80/ export socks_proxy=http://proxy.cat.com:80/ else if grep -q "https://proxy.cat.com" /etc/environment; then echo "/etc/environment contains invalid proxy settings, please remove all proxy settings from this file and rerun this script" echo "Execute the following command, remove all "proxy" lines, save and close: 'sudo gedit /etc/environment'" exit 2 fi echo "/etc/environment already configured with a proxy" fi
Pilot6
  • 92,041
