I am running netmaker which is a wireguard mesh VPN service on a Docker container, and I need port 9981 to be reachable from the Docker container, so that I can access port 9981 via my Wireguard WAN.
Port 9981 is open on the VPS on which Netmaker is hosted, but isn't reachable from within the Docker container. I have been trying to no avail to get this right, and I'm now at my wits end.
I was advised to add this line to my docker-container file which has just caused error after error -
PORT_FORWARD_SERVICES="127.0.0.1:9981:9981"
Please can someone assist.
Artur Meinild
  • 31,035
Did you try the Docker documentation? Port forwarding is a pretty standard feature in Docker.
In a normal CLI syntax you add:
-p <host-port>:<container-port>
This is an example command that maps port 443:
docker run -d \
  --name=nextcloud \
  -e PUID=1000 \
  -e PGID=1000 \
  -e TZ=Europe/London \
  -p 443:443 \
  -v /path/to/appdata:/config \
  -v /path/to/data:/data \
  --restart unless-stopped \
  lscr.io/linuxserver/nextcloud:latest
So you need to add -p 9981:9981 to the command you use to run your container.
There is also a similar syntax if you use Docker Compose (but since you didn't specify I assume this isn't the case).
Artur Meinild
  • 31,035
