I updated from Ubuntu 20.04 to 22.04 and login went up from almost instantly in Ubuntu 20 to 2.5 minutes in Ubuntu 22!!!
Booting takes longer as well (appr. 50 secs.) Normally all start-up text races by, but now the following text stays on screen for about 20 secs.
Running /scripts/local-premount
It's the user login that takes 2:15 where only my backdrop is visible.
I have a Asus P8Z77-V MB (some 10 yrs old). Processor Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz
Memory 16066MB (3188MB used)
Kernel Linux 5.15.0-37-generic (x86_64) Version #39-Ubuntu SMP Wed Jun 1 19:16:45 UTC 2022
C Library GNU C Library / (Ubuntu GLIBC 2.35-0ubuntu3) 2.35
Distribution Ubuntu 22.04 LTS
Mesa Intel(R) HD Graphics 4000 (IVB GT2) Version 3.1 Mesa 22.0.1
I wanted to check logs, but don't know which and what to look for.
No NVidia card.
Any help appreciated.
Thanks
EDIT1
During 1st upgrade from 20.04 to 22.04 the installer stopped because I didn't have enough space on my / (root) partion (30GB).
I started a Live Linux version from an USB stick and used Gparted to resize the Ext4 root partition with an extra 30 GB. This went all without problems and so did the following update to 22.04.
I have the following partitions on my 128 GB SSD:
sda1 : fat32 /boot/efi 190MB
sda2 : ext4 /boot 572MB
sda3 : ext4 / 58.59GB (was appr. 30GB before resizing)
Furthermore 2 small data partitions:
sda4 : ext4 LUKS encrypted
sda5 : ext4 data
My home directory is on a 1TB standard harddrive (sdb)
Below I've included output from system-analyze
$ systemd-analyze
Startup finished in 2.717s (firmware) + 4.301s (loader) + 34.923s (kernel) + 6.285s (userspace) = 48.228s
graphical.target reached after 6.278s in userspace
$ systemd-analyze blame 3.579s NetworkManager-wait-online.service 1.531s snapd.service 1.163s dev-sda3.device 998ms udisks2.service 940ms dev-loop12.device 939ms dev-loop13.device 939ms dev-loop11.device 939ms dev-loop10.device 935ms dev-loop8.device 935ms dev-loop9.device 933ms dev-loop15.device 929ms dev-loop14.device 829ms blueman-mechanism.service 762ms dev-loop1.device 761ms dev-loop4.device 760ms dev-loop5.device 760ms dev-loop7.device 742ms dev-loop3.device 730ms dev-loop6.device 710ms dev-loop2.device 687ms dev-loop0.device 672ms snapd.seeded.service 626ms smartmontools.service 574ms cups.service 543ms user@1000.service 502ms accounts-daemon.service 463ms networkd-dispatcher.service 421ms ModemManager.service 290ms systemd-resolved.service 260ms polkit.service 258ms systemd-journal-flush.service 242ms NetworkManager.service 242ms avahi-daemon.service 238ms systemd-timesyncd.service 203ms nginx.service 190ms systemd-rfkill.service 190ms gpu-manager.service 163ms thermald.service 160ms apparmor.service 159ms wpa_supplicant.service 159ms systemd-logind.service 156ms e2scrub_reap.service 150ms apport.service 149ms secureboot-db.service 141ms systemd-udev-trigger.service 135ms systemd-udevd.service 133ms grub-common.service 127ms colord.service 121ms snapd.apparmor.service 119ms alsa-restore.service 108ms rsyslog.service 107ms resolvconf-pull-resolved.service 105ms systemd-fsck@dev-mapper-fedora\x2dhome.service 104ms systemd-journald.service 104ms keyboard-setup.service 102ms lightdm.service 100ms upower.service 86ms lm-sensors.service 85ms lvm2-monitor.service 82ms lvm2-pvscan@8:18.service 82ms systemd-modules-load.service 73ms sys-kernel-tracing.mount 73ms sys-kernel-debug.mount 72ms dev-mqueue.mount 72ms dev-hugepages.mount 69ms modprobe@fuse.service 67ms kmod-static-nodes.service 65ms modprobe@drm.service 65ms modprobe@configfs.service 65ms snap-bare-5.mount 64ms virtualbox.service 62ms WiLiShare.mount 62ms snap-chromium-2000.mount
