I am experiencing very slow boot times on reboot and I have to manually restart 2-3 times to get to a regular boot for it to boot properly. This just started one day and has been happening ever since (before this problem started, the system would boot in 5secs from the time the Ubuntu logo appeared on the screen). I am getting "a start job is running for /boot/efi" at the start and then several lines with journal checking and so on.
I have looked on other threads people reporting the same issue and it seems to be caused by a /etc/fstab erroneous uuid. But I checked sudo blkid and /etc/fstab output and they seem to match.
sudo blkid output:
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/nvme0n1p1: LABEL="SYSTEM" UUID="40F6-B9B6" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="96888f3a-32b4-4c29-a97a-0a2752032570"
/dev/nvme0n1p3: LABEL="Windows" UUID="AEB4F937B4F9029F" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="69a69e0a-938c-42ce-9226-be4c125ee402"
/dev/nvme0n1p4: LABEL="WinRE_DRV" UUID="E0B4F9BEB4F9976E" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="8c6c7f7d-4df1-40cc-a2b1-f0dc3013f00a"
/dev/nvme0n1p5: UUID="d4d0677a-3d4f-4c7c-96f4-66ed734a5a3d" TYPE="ext4" PARTUUID="4452c614-1e43-4141-91f7-46c009f9f177"
/dev/nvme0n1p6: UUID="a718d4e2-923d-4377-ad85-99693a258718" TYPE="swap" PARTUUID="9d01bb23-5e03-4854-802d-de338d04a749"
/dev/loop8: TYPE="squashfs"
/dev/loop9: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop13: TYPE="squashfs"
/dev/loop14: TYPE="squashfs"
/dev/loop15: TYPE="squashfs"
/dev/loop16: TYPE="squashfs"
/dev/loop17: TYPE="squashfs"
/dev/loop18: TYPE="squashfs"
/dev/loop19: TYPE="squashfs"
/dev/loop20: TYPE="squashfs"
/dev/loop21: TYPE="squashfs"
/dev/loop22: TYPE="squashfs"
/dev/loop23: TYPE="squashfs"
/dev/loop24: TYPE="squashfs"
/dev/loop25: TYPE="squashfs"
/dev/loop26: TYPE="squashfs"
/dev/loop27: TYPE="squashfs"
/dev/loop28: TYPE="squashfs"
/dev/loop29: TYPE="squashfs"
/dev/loop30: TYPE="squashfs"
/dev/loop31: TYPE="squashfs"
/dev/loop32: TYPE="squashfs"
/dev/loop33: TYPE="squashfs"
/dev/loop34: TYPE="squashfs"
/dev/loop35: TYPE="squashfs"
/dev/loop36: TYPE="squashfs"
/dev/loop37: TYPE="squashfs"
/dev/loop38: TYPE="squashfs"
/dev/loop39: TYPE="squashfs"
/dev/loop40: TYPE="squashfs"
/dev/loop41: TYPE="squashfs"
/dev/loop42: TYPE="squashfs"
/dev/loop43: TYPE="squashfs"
/dev/loop44: TYPE="squashfs"
/dev/loop45: TYPE="squashfs"
/dev/loop46: TYPE="squashfs"
/dev/loop47: TYPE="squashfs"
/dev/loop48: TYPE="squashfs"
/dev/loop49: TYPE="squashfs"
/dev/loop50: TYPE="squashfs"
/dev/nvme0n1: PTUUID="6b27bf65-2dd5-46ec-aaa7-7a757af74c48" PTTYPE="gpt"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="c8291373-5fbb-4874-b897-fc75feb2b9f6"
/etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/nvme0n1p5 during installation
UUID=d4d0677a-3d4f-4c7c-96f4-66ed734a5a3d / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/nvme0n1p1 during installation
UUID=40F6-B9B6 /boot/efi vfat umask=0077 0 1
# swap was on /dev/nvme0n1p6 during installation
UUID=a718d4e2-923d-4377-ad85-99693a258718 none swap sw 0 0
Does anyone know what is causing this? Edit: I'm on Ubuntu 18.04
