27
I need to install an older version of Python to get some software to work. 3.9 is the newest version I can use.
Someone else had this issue and the answer was:
sudo add-apt-repository universe
sudo apt update
sudo apt install python3.9
However this does not work and just gives an error that the 3.9 package can not be found.
So how can I remove 3.10 and get 3.9 instead? Thanks.
fletch
  • 371
I encourage to install just your python dependencies using a python package, as this other question and answer suggest: How do I install a different Python version using apt-get?
sudo add-apt-repository ppa:deadsnakes/ppa
sudo apt-get update
sudo apt-get install python3.9
cserpell
  • 440
Install anaconda https://phoenixnap.com/kb/how-to-install-anaconda-ubuntu-18-04-or-20-04
Anaconda manages different versions of python and their packages by creating environments that are isolated.
So you can install whatever versions of python without crushing.
conda create --name envp39 python=3.9
This creates python environment with python 3.9
You can switch version by changing environments with
conda activate envp39
You have to open/install the software in a shell with activated envp39.
Tom
  • 725
I think the most pythonic way would be to create a virtual environment and then run your script in the env. For example, if you have miniconda/Anaconda installed,
$ conda create -n your_env_name python=3.9
$ conda activate your_env_name
Install all packages you need:
(your_env_name) $ conda install package_name
If the package is not in conda,
(your_env_name) $ cd ~/your_conda_directory/envs/your_env_name/bin
(your_env_name) $ pip install package_name
Make sure you verify Python version
(your_env_name) $ python --version
Python 3.9.12
And now you are good to go:
(your_env_name) $ python your_code.py
Good luck!
