The thing is that I am starting after a few months of experience in linux to use the command line. I was trying to use a new "cursor theme". I found on reddit that I needed to move the file from the "Download" directory to /usr/share/icons. Because it didn't work I figured it needed to be moved to the second option the reddit post stated: ~/.local/share/icons . I then figured that the reason why it didn't work was because it was a compressed file. These are the commands that I put into the terminal.
~$ sudo mv /usr/share/icons/posy-s-cursor.tar.gz /usr/share/icons/breeze_cursors
~$ ls /usr/share/icons/breeze_cursorscursors  index.theme  posy-s-cursor.tar.gz
mv /usr/share/icons/breeze_cursors/posy-s-cursor.tar.gz ~/.local/share/icons
mv: cannot move '/usr/share/icons/breeze_cursors/posy-s-cursor.tar.gz' to '/home/x/.local/share/icons': Permission denied
~$ sudo mv /usr/share/icons/breeze_cursors/posy-s-cursor.tar.gz ~/.local/share/icons
~$ sudo mv  ~/.local/share/icons/posy-s-cursor-tar.gz /usr/share/icons/breeze_cursors/posy-s-cursor.tar.gz
mv: cannot stat '/home/x/.local/share/icons/posy-s-cursor-tar.gz': Not a directory
I would appreciate if someone would please:
  • locate the posy-s-cursor.tar.gz file and state me how to move it to /usr/share/icons
  • tell me how to decompress a file using the command line.
Thanks a lot usrs.
ethcz
  • 239
milintime
  • 129
To find your file, search in the two folders that you have been dealing with:
find /usr/share -name "posy-s-cursor.tar.gz"
find /home/x -name "posy-s-cursor.tar.gz"
See linuxhint.com or man find for more info on find command.
If not found, you may search other areas, but this could take pretty long. For much faster search over the whole disk, you can use locate (see askubuntu page regarding installing locate), but it is trickier to use as the database needs to be updated (with command sudo updatedb) in order to work properly with newly created/copied/moved files). Or just forget about the lost file and download it again.
Your last command
would work for you, if:
  • your file posy-s-cursor-tar.gz exists in ~/.local/share/icons/
  • full path /usr/share/icons/breeze_cursors/ already exists (including the directory breeze_cursors. If not, the missing directory needs to be created first with mkdir.
To extract the tar.gz into the current directory (supposing you are in the directory, where your tar.gz file is located):
tar -xvf posy-s-cursor.tar.gz
See linuxhint.com or man tar for more info on tar command.
ethcz
  • 239
