i am currently trying to run Parsec on my Ubuntu 22.04 to connect to my remote Windows gaming rig.
On this support page: https://support.parsec.app/hc/en-us/articles/115003477771-Using-Parsec-With-other-Linux-Distros
it says which libraries are required.
As far as i can tell via synaptic is that the only dependend package missing is "libcrypto.so.1.0.0 (or 1.1)"
If i search in synaptic for "libcrypto" i find a few libcrypto++ packages but none of them work.
Is there any other source where i can find a .deb file of this missing library?
Thank you guys in advance <3
Issykul
  • 31
Installing libssl1.1, which provides libcrypto.so from 21.10 sources solved this for me. To do so, I followed the steps from this answer (MongoDB apparently has a similar issue): https://askubuntu.com/a/1403683
To quote the necessary commands from the answer:
echo "deb http://security.ubuntu.com/ubuntu impish-security main" | sudo tee /etc/apt/sources.list.d/impish-security.list
sudo apt-get update sudo apt-get install libssl1.1
After the installation, I've removed the sources from 21.10 again. (Edit the created /etc/apt/sources.list.d/impish-security.list again and comment out the line by putting a # at the beginning.)
After Ubuntu 21.10 (Impish Indri) has reached End of Life this should work:
echo "deb http://old-releases.ubuntu.com/ubuntu impish-security main" | sudo tee /etc/apt/sources.list.d/impish-security.list
sudo apt-get update
sudo rm /etc/apt/sources.list.d/impish-security.list
Pilot6
  • 92,041
jochen
