I want to see if I can delete all themes and fix the Notification I have. I have deleted the PPA's, but the themes are still in Gnome Tweak. Where are themes located so I can remove them? Thanks.
atenz
  • 12,858
chazdg
  • 575
Themes are normally located at:
If installed via PPA:
/usr/share/themes/
If installed locally:
~/.themes/
Removing themes:
PPA ones:
sudo apt-get remove <theme_package_name>
Local ones:
rm -rf ~/.themes/*
Don't forget to set your GTK theme to the default first, otherwise your current session might go nuts :)
They should be in /usr/share/themes, but if you installed them via ppa you shouldn't just remove the Folders but remove the packages with Software Center or apt-get!
jplatte
  • 1,290
Themes can be in two folders depending on how you installed them
First it is here
/usr/share/themes
Second is here
.Themes
Which is located in your Home file , please click Ctrl+H or Show Hidden Folders from View Menu.
But please take a caution while deleting the Default Installed themes Packed by Ubuntu.
atenz
  • 12,858
